Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
March 06, 2021, 02:42:22 PM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Starter Motor
Print
Pages:
1
2
3
4
5
25
Go Down
Author
Topic: Starter Motor (Read 67050 times)
muedet
Tiger Cub
Bike: 800XrX
Re: Starter Motor
Reply #20 on:
November 09, 2015, 09:29:50 AM »
Reading german is sufficient, speaking not necessary
Of course you're right, but the pictures are doing a bit of translation .
In fact you will need to replace the brushes and revise the collector on a turning machine.
Logged
chuckxc
Premier Member
Tiger Master
Bike: 12XC, 18XCX
Re: Starter Motor
Reply #21 on:
November 13, 2015, 08:41:52 AM »
The Brushes are worn down completely after 50k km. Piccie here. Triumph (or Denso) won't sell replacement brushes, just the whole starter motor for over $700. A case of gouge the customer.
Logged
D6864
Tiger Master
Bike: White XC
Re: Starter Motor
Reply #22 on:
November 13, 2015, 09:10:26 AM »
Try an automotive electrical specialist; I'm pretty sure you will find replacement brushes even if you have to file them down to fit the holders, for example:
http://ricksmotorsportelectrics.com/starter-brushes
Logged
chuckxc
Premier Member
Tiger Master
Bike: 12XC, 18XCX
Re: Starter Motor
Reply #23 on:
November 13, 2015, 10:03:18 PM »
Thanks D6864, I did turn the commutator down on the lathe and tried to source other brushes, unfortunately I could only find pure carbon, not copper/carbon material like the original. So l'll try the website you mentioned and see if they have something better.
Used to be able to buy brushes by the bucket load, but these days the OEMs lock them up so we are forced to buy the whole motor.
Logged
chuckxc
Premier Member
Tiger Master
Bike: 12XC, 18XCX
Re: Starter Motor
Reply #24 on:
December 01, 2015, 09:23:29 PM »
Having now purchased a replacement starter motor from Triumph for too much money I believe there is probably a design or manufacturing defect in the original Denso starter motors, P/N 428000-5540, which have now been upgraded to -5542. I suspect it was in at least the Tiger 800XC 2011-2012 models, based on the forum reports.
Common failure symptoms in almost all cases include slow or insufficient cranking power when the engine becomes hot, say when idling in hot weather. Acts as if it is a weak battery but it is not, it is a failing starter motor. Once the engine and thus the starter motor cool, it will start again. This problem occurs more frequently until the motor finally fails at around 50K km.
Also, on another unrelated issue, the grounding of the starter motor is minimal, depending on two small areas under the mounting tangs contacting the engine block, and prone to corrosion. I modified the connection when I replaced the motor.
Chuck
Logged
Tikru
Tiger Member
Bike: White ABS Roadie
Re: Starter Motor
Reply #25 on:
January 05, 2016, 04:46:36 PM »
Originally Posted by
chuckxc
Hi,
according to the German forum you need to order the following parts:
Denso 028512-5470 isolator x1
Denso 028530-5302 holder x1
Denso 028530-5312 brush x2
www.al-electric.de
Key the numbers into the "Nach nummer" window, "Suche"=find
"Warenkorb"=cart
"Aktualisieren"=update
Parts 24,06 euros, delivery by DHL to "Neuseeland" 40,40
I am interested in this because i have 2011 Roadie 58 k on the clock, no problems so far.
Last Edit: January 05, 2016, 04:51:08 PM by Tikru
Logged
You can only be young once. But you can always be immature. Dave Berry
chuckxc
Premier Member
Tiger Master
Bike: 12XC, 18XCX
Re: Starter Motor
Reply #26 on:
January 05, 2016, 10:04:23 PM »
Good work, Tikru, you have found the correct replacement parts. I have looked at the website pictures and they are the same as those removed from my starter motor, so I am sure they are the right ones.
Thanks for your efforts.
Chuckxc
Logged
hobie
Tiger Pro
Bike: 800 white&silver
Re: Starter Motor
Reply #27 on:
January 10, 2016, 07:27:21 PM »
I think I might have this problem as well. My bike is 2011 with 43K kms on it. It won't start while hot, but does after cooling a bit. However, the starter motor turns quite normally; the engine doesn't 'catch' is all. Is this what others are seeing as well, or would the starter not turn at all if the brushes were worn out?
I had just had my 40K service/valve adjustment before this started happening and the software was updated. Could this be the cause?
I had the battery tested, and was told it is fine.
Last Edit: January 10, 2016, 07:39:43 PM by hobie
Logged
chuckxc
Premier Member
Tiger Master
Bike: 12XC, 18XCX
Re: Starter Motor
Reply #28 on:
January 10, 2016, 08:18:34 PM »
If the engine won't engage, probably the starter motor is not spinning fast enough. But if it is ok when cooled down, then sounds like it could be the same problem. My test was to get it hot until it faults, then quickly hose it with cold water until cool and try to start again.
Logged
gfleck
Tiger Pro
Bike: none
Re: Starter Motor
Reply #29 on:
March 11, 2016, 12:01:41 PM »
Reactivating the thread.
There was a recent case on Brazilian forum with a ST3, same problem of starter motor fail. As we know, Triumph deny warranty.
So, a mechanic discovered that the brushes of Suzuki Burgman works on the starter motor of ST3. He fix it for $10,00.
The question is, the starter motor of ST3 is equal to the Tiger?
Logged
San Pedro de Atacama, Chile and Machu Picchu, Peru - 2013 (
http://gfleck.qsl.br/primospicchu
Ruta 40, Argentina - 2014
Pantanal, Brazil - 2015
Italy, Rome to Siracusa - 2017
Print
Pages:
1
2
3
4
5
25
Go Up
Starter Motor
Happy new bike day
Stevie.P
Today
at 02:04:39 PM
TPMS
Tyres and Wheels
T800XC
Today
at 01:22:04 PM
Touratech Small windscreen
Accessories and Products
samsgrandad
Today
at 12:17:09 PM
Engine management light on after dead battery
Stevie.P
Today
at 10:42:35 AM
return to triumph
New Members
Whoa
Today
at 07:55:59 AM
Happy Birthday x10
PapaTom
Today
at 07:27:32 AM
2016 800XRt - Removing Throttle Restriction?
ECU Re-Mapping and Tuning
paul_o
Yesterday
at 09:58:00 PM
Problems with fork removal
pennpeel
Yesterday
at 06:03:47 PM
Hello!
New Members
Tigermainia
Yesterday
at 06:00:58 PM
Multimeter Recommendations
AvgBear
Yesterday
at 04:55:01 PM
