Point taken, there is alot of room to put all the wires other side of the plastic bit with the V showing (right hand side)
But the only trouble is you need to carry a 8mm spanner to undo the 4 bolts holding the back cover on!!
I am going to fit a Givi top box to mine so too much trouble to take it all off again.
It could be good place to carry extra cash if you have any spare these days!!I have put a small pocket tool kit under lube tube, just in case of trouble, might even put some spare fuse's there,only hope I have a 8mm spanner handy if needed.v
