Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Charging points  (Read 1004 times)
Offline 1157jonboy
  • They tell me the throttle works both ways.
  • Bike: Tiger 800 xc
Charging points
« on: May 05, 2014, 11:03:18 AM »
Does anyone do a lead that fits the iPhone 5 and the 12 volt auxiliary charging points on the bike? I've never used the aux charging points for anything before, and just wondered. Also if I buy a sat nav or heated clothing, are the plugs/leads a standard size that will fit the bike? Forgive my ignorance as I've only had the tiger a few months and never needed to use them!
Cheers, Jon
Offline serfies_sa
Re: Charging points
« Reply #1 on: May 05, 2014, 12:08:43 PM »
Offline knapdog
Re: Charging points
« Reply #2 on: May 05, 2014, 02:03:35 PM »
To charge anything on a bike I use one of these. It's called a Hella Din USB plug (forget that it says BMW as it can be used on many bikes). The Tiger 800 has an auxiliary socket that is not like a car cigarette charger, which tend to be fatter. The socket looks a lot thinner and is designed for the DIN plug. This one has two USB sockets so you can recharge what you want:
Just type in this number on ebay search:
380888233300
Offline Colshie
  • 2013 Tiger 800 ABS bought.....get it Thursday!!!
  • Bike: Tiger 800 ABS
Re: Charging points
« Reply #3 on: May 05, 2014, 03:17:15 PM »
Thanks guys, useful post as I've just got my bike.  :460:
Honda CB500(1999-01), HondaCBR600(2001-2014), Triumph Tiger 800R ABS
Offline Skez
  • Its a way of life, live the dream
  • Bike: Tiger800, Sv650s
Re: Charging points
« Reply #4 on: May 14, 2014, 11:28:21 AM »
Morning all,
I've just found this post through the search function, very helpful, i do however have a question.
I resently bought one of those solar panels which you place in you car windscreen and plug in to the cigarette light to trickle charge your battery.
If i buy a Din plug with a female cigarette type socket on the other end can i plug it in to maintain the battery.
The solar panel will charge all batteries up to 100ah.
Regards
« Last Edit: May 14, 2014, 11:32:23 AM by Skez »
