Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
February 28, 2021, 06:44:53 PM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Fog lights to follow high beam
Print
Pages:
1
2
Go Down
Author
Topic: Fog lights to follow high beam (Read 5219 times)
interactive3
Tiger Member
Bike: Tiger 800 XCx
Re: Fog lights to follow high beam
Reply #10 on:
May 03, 2015, 03:48:08 AM »
Originally Posted by
Heimdall
Thanks for all the help guys, finally got around to it.
Thought I'd post how I did it, if I did it right someone might benefit from it as a reference and if I screwed it up I'm counting on you to save the bike (still in winter storage) before I fry it.
Could not find a better way so I spliced in to the white/blue high beam cable at the connector behind the headlights (removed them to get to it).
So now I can operate the fog lights (which aren't really fog lights at all but cree LED aux lights in OEM fittings and harness) in day time with the low beam but have the luxury of not needing to operate two switches to get maximum light output at night.
I'd say total cost of the entire project was < €10 so money well spent.
Thanks for posting this. I had Clearwater LED Lights on my 1050 and loved the change to full brightness when the high beams were triggered.
Logged
dasf
Tiger Member
Bike: 800 XCA 2017
Reply #11 on:
December 09, 2020, 09:33:15 AM »
Have a Triumph Tiger 800 XCA 2017 with OEM Fog (LED) installed from factory. Now trying to get a relay into the harness so I don’t have to hit two switches when going from High- to Low beam at night. Planning to break up the +12 v circuit to the fog lamp at the Fog light switch connector at the right side of the cooler ( see picture) but got into a problem. When testing the cables at this connector I found that red cable have 12 volt when the fog light switch is on AND off. How come? Where can I break up the circuit and place the relay?
Last Edit: December 09, 2020, 09:56:03 AM by dasf
Logged
dasf
Tiger Member
Bike: 800 XCA 2017
Reply #12 on:
December 09, 2020, 01:49:20 PM »
Did some more testing and found that the foglights still function as they should, on and off, via the handlebar switch if I disconnect connector 4. Don't understand........
Logged
pme
Tiger Member
Bike: xrx lrh 2018
Reply #13 on:
December 09, 2020, 04:20:50 PM »
if it the same design as the 2018 model, its all controlled via a relay and the ecu. If not is possible that the system applies ground via the relay/switch combo, the old horn used to be that way, when you pressed the horn button the ground is made and the horn sounds. 12v +ve is constant, that was why you could use the +12v on the horn connector for a swiched 12v supply to a gps etc..
Logged
dasf
Tiger Member
Bike: 800 XCA 2017
Reply #14 on:
December 15, 2020, 03:24:42 PM »
As the fog light on my Tiger 800 XCA 2017 seems to be controlled by the ECU I had to come up with a DIY solution to get my DRL and fog light work as I and the police want.
Now at daylight the DRL and foglight (if on) is on at high- and low beam and
at night the DRL and foglight (if on) is on at high beam and off at low beam.
Also the DRL and foglight (if on) at night is controlled by the high/beam switch and I don’t have to use two switches.
The needed toggle switch and relays is mounted non visible but reachable behind the left lower panel.
Logged
Print
Pages:
1
2
Go Up
Hazard lights will not turn off.
Stevie.P
Today
at 05:24:16 PM
Tiger ELM327 OBD2 devices and fork oil replacement
Stevie.P
Today
at 11:04:28 AM
Idle speed rising/hunting with clutch in
Misc Technical Help Required
Derchef1962
Today
at 10:05:29 AM
Hi from Spain
New Members
Tigermainia
Today
at 09:51:06 AM
Tiger 900 Basic 2020 -Wiring diagram
Admin
Today
at 08:45:50 AM
Screw-on Aftermarket TPMS Integrated Into Dash!
Tyres and Wheels
celbey
Yesterday
at 08:44:19 PM
Gone over to the dark side.
On Two Wheels
Snownorge
Yesterday
at 05:02:41 PM
2017 XCX Cruise Control
casimiro
Yesterday
at 03:59:57 PM
REGINA MAINTENANCE FREE CHAIN
bybecker
Yesterday
at 01:56:24 PM
Got the new baby home! :)
RTV
Yesterday
at 09:34:45 AM
