Let's address those pesky future problems you haven't had yet with your new Tiger 800.
Windscreen buffeting at highway speeds.
A. Try lots of aftermarket screens.
B. Use earplugs.
Headlights don't properly illuminate the road at night.
A. Add accessory lighting.
B. Ride in daytime.
Throttle response is abrupt due to lean fueling.
A. Re-learn everything your right hand knows about fine-motor skills.
B. After-market electronics makers will get right on this problem.
Bike makes weird Martian sounds when you turn off the ignition.
A. Don't ignore this... something has got to be wrong.
B. Back slowly away from the machine, and don't try to respond.
Suspension is not up to track-day antics.
A. Spend additional $2500 on Ohlins components.
B. Attempt to be more accepting in nature.
The crankshaft cam chain end sheared off causing piston to valve contact, thus shrapnel-izing the entire engine.
A. Be friendly with your dealer, bring him some cookies.
B. Wait a model year or two before purchase to let them get the "bugs" out.
Everyone thinks it looks too much like a BMW.
A Show them where it says Triumph on the tank.
B. Casually make farting noises in their direction.
The bike weighs too much, doesn't have an 8 gallon tank, doesn't have the rear sub-frame you wanted, it's too short, it's too tall, you can't flat-foot the ground, it makes your butt look big, it's got plastic instead of carbon fiber, it doesn't have 180 hp., no cup holders, the electronics don't prevent high sides at 120 mph. during a snow storm, you wanted a red one, and the turn-signals don't self-cancel.
A. We just can't have anything nice around here.
B. The honda-duc-ktm-bmw-susuki you wanted is over there somewhere.
