Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Bar Risers for 800 XRT  (Read 2500 times)
Offline Silverfox
  • Bike: Tiger XRT 2016
« on: March 01, 2016, 03:34:44 PM »
Hello, New Member here and picking up my NEW 16 plate XRT Wednesday.
I would like to purchase Bar Risers to bring bars up say 20cm and Definitely back 20cm, to give me a more comfortable position.
The Triumph dealer only has risers that only Lift up to 30.
Any help appreciated
Re: Bar Risers for 800 XRT
« Reply #1 on: March 01, 2016, 03:47:29 PM »
Surely if the risers are angled back they reduce the effective rise?
You'd have to do the trig to work out what rise you need to allow for a horizontal 20mm shift to the rear
EDIT: I reckon about 30mm (28.3mm) :)
« Last Edit: March 01, 2016, 03:51:14 PM by Rtwo »
« Reply #2 on: March 01, 2016, 04:08:35 PM »
 :401: Hi, I have the Triumph risers on my XRt and as you say they lift the bars 30mm and can be reversed to move the bars back a bit, haven't measured but maybe 10mm?
There Rox I believe are a 2" (50mm) rise and variably adjustable?.
There is SW-Motech who do are a 20mm riser listed for the XC (basically a straight spacer), but with no rearward move and shown fitted under the Triumph risers. These should work no problem? Although you would have to source your own 2 replacement screws 20mm longer than standard as the supplied ones are obviously for the using with the 30mm risers.
http://www.motohaus.com/acatalog/Triumph-Tiger-800-XC-1200-XC-Bar-Risers.html
Offline Stevie W
  • Non-Active
  • Bike: Tiger 800xc
Adventure bikes are like Garlic Bread, I've tasted it, it's the future.
