Author [NL] [FR] [ES] [DE] [SE] [IT] BikeVis Bullets v2 Installation Help please  (Read 2619 times)
  • Offline The Stealth   gb
    • Non-Active
    • Tiger Jedi  ‐    1834
    Offline The Stealth
    • Non-Active
    • Bike/Model: Black Tiger 800
    • Country: gb
    on: Mar 09, 2016, 12.17 pm
    Hi everyone, I have just ordered bullet lights from Bikevis, now I am no sparky so I need a little advice on fitting these little buggers  :001:
    I have a 2012 Roadie with OEM fog/aux lights fitted, and the OEM switch to turn them on and off, I would like to if possible splice into that switch so's that it turns my fog/aux lights on as well as the new bullets from bikevis, now I'm not sure if that's possible but I'm hoping that one of my fellow forum members will have all the answers I'm looking for
    The Stealth  :017:
  • Offline Greg   gb
    • Tiger Jedi  ‐    3819
      #1
    Offline Greg
    • Tiger 800 No2.. Scrambler.. Mahoosive Yamaha
    • Bike/Model: Tiger 800...
    • Country: gb
    Re: BikeVis Bullets v2 Installation Help please
    Reply #1 on: Mar 09, 2016, 01.19 pm
    Not sure if the Triumph switch will run two sets of lights due to the internal electronics.. Run them of a separate switch and a second relay.
    Buy another Triumph switch and loom.. It's what I did for my second set of lights.
    Greg
    It's a terrible thing, I think, in life to wait until you're ready. I have this feeling now that actually no one is ever ready to do anything. There is almost no such thing as ready. There is only now. And you may as well do it now. Generally speaking, now is as good a time as any.”
    Hugh Laurie
  • Offline T800XC   ua
    • Tiger Jedi  ‐    2682
      #2
    Offline T800XC
    • Bike/Model: Tiger 1200 XRT
    • Country: ua
    Reply #2 on: Mar 09, 2016, 01.54 pm
    Those bullet LEDs are less than 1W each so shouldn't be a problem just tapping them into the wires that go to your existing fogs.
    Greg's additional fogs were much higher current than the bullets so we ran an extra switch & relay to control them. In your case you could still do that if you wanted to have independent control of the bullets & fogs. However, the Triumph fog switch itself is capable of driving the bullet LEDs directly without the need for an extra relay, so that's another option open to you.
    • Non-Active
    • Tiger Jedi  ‐    1834
    • #3
    Offline The Stealth
    • Non-Active
    • Country: gb
    Reply #3 on: Mar 09, 2016, 02.06 pm
    I would rather not have another switch if I don't need one, I'd very much like to go down the route of using the OEM switch I already have, so now what where would I splice into too achieve this, the bullets I'd like to put lower than the fog/aux lights perhaps on the crash bars if that helps
    Again cheers for all your help
    The stealth  :017:
  • Offline DaMonk45
    • Tiger Master  ‐    342
      #4
    Offline DaMonk45
    • Bike/Model: Explorer
    Reply #4 on: Mar 09, 2016, 03.41 pm
    I am thinking that if you cut into that wire harness you may have warranty issues if anything goes bad.
    Im not sure of this so it might be worth looking into.
  • Offline Todi
    • Tiger Member  ‐    96
      #5
    Offline Todi
    • Bike/Model: '15 Tiger 800XRx
    Reply #5 on: Mar 09, 2016, 04.13 pm
    *Originally Posted by DaMonk45 [+]
    Don't cut the harness, use T-Tap or Posi-Tap by the OEM connectors to connect the new LED lights.
    2007 CB900F 919 Hornet - traded
    2015 Tiger 800XRx
  • Offline mym   gb
    • Tiger Member  ‐    29
      #6
    Offline mym
    • Bike/Model: Tiger 800 XR
    • Country: gb
    Reply #6 on: Nov 04, 2021, 04.53 pm
    just bought some of these myself, however i would like the bullets to be on all the time as my dip beam lights are.
    is a t-tap the best to get the power/ground for them, or is there something a little more elegant i can do to get power?
  • Offline Greenman   gb
    • Tiger Member  ‐    45
      #7
    Offline Greenman
    • Bike/Model: Tiger 800 XRx
    • Country: gb
    Reply #7 on: Nov 04, 2021, 08.34 pm
    I’ve just looked up these bullet lights and they look really compact and low wattage, has anyone posted pics of their mounting? I guess it’s similar on XR and XC?
    Just doing as much as I can for as long as I can.
