Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Manual idle adjuster.  (Read 15189 times)
Offline NORTY
  • RiderCoach
  • Bike: 2012 800XC
Re: Manual idle adjuster.
« Reply #10 on: October 02, 2016, 04:26:53 AM »
The bike would be better off without the stepper motor. Unless Triumph figured out a way to make it work in all the conditions the bike might be subjected to. I see they fixed the problem by removing it in later editions. Now, if we could just get Triumph to listen to reason regarding the retarded gear ratios they chose...
MSF RIDERCOACH (RETIRED!) :)
I also ride my Husqvarna 701 Enduro. (Been known to ride the "Vet" track @ Fox Raceway.) If you see and old, fat guy on a 701E, it's likely me!
Believe it or not, I'm down to 2 bikes!
Offline Cats
  • Bike: 800XC
« Reply #11 on: April 21, 2017, 05:27:22 PM »
Been looking at this mod and can anyone confirm that this >  http://www.worldoftriumph.com/triumph_motorcycle_parts_locator.php?block_01=&block_02=100063443-0-2&block_03=610414
is the part that I need?
Offline Cats
  • Bike: 800XC
« Reply #12 on: April 24, 2017, 03:41:31 PM »
No one?  I've tried pm'ing Locky but had no reply.
Oh well, might just have to take a punt.
Offline bluestar
  • Bike: 2014 800XC
« Reply #13 on: April 24, 2017, 03:46:26 PM »
I'm almost positive that it is the correct one but I haven't used it myself.  :027:
Offline itchywheels
  • Bike: XT600Z Tenere
« Reply #14 on: May 02, 2017, 12:42:02 PM »
Did you buy it Cats ?
Into the great wide open, under the skies of blue. Out in the great wide open, a rebel without a clue !!
Offline Cats
  • Bike: 800XC
« Reply #15 on: May 02, 2017, 02:04:27 PM »
I got a late reply from Locky and he informed me that it's this one > http://www.jacklilley.com/buy/Triumph-Manual-Idle-Adjuster-Kit/A9618076  Whether it's the same I don't know, but this is the one I've ordered from Jack Lilley Triumph and just waiting on it's arrival. As to when i'll be fitting it ???
Offline itchywheels
« Reply #16 on: May 03, 2017, 03:37:31 PM »
Thanks again Cat. Can you remove the stepper motor totally ? Anybody  :027:
Offline Cats
  • Bike: 800XC
« Reply #17 on: May 04, 2017, 03:08:34 PM »
When I get round to the mod i'll try it and see what happens. The adjuster turned up today so i'll keep you posted.
Offline bluestar
  • Bike: 2014 800XC
« Reply #18 on: May 04, 2017, 03:12:33 PM »
*Originally Posted by itchywheels [+]
Removing the stepper motor will cause the check engine light to come on. Just unbolt it and zip tie it out of the way.
Offline locky
  • Bike: Tiger 800xc
« Reply #19 on: May 11, 2017, 10:31:37 PM »
 Yes the stepper motor needs to stay connected.  Im interested how you get on with the manual adjuster. Mines been fine since fitted.
