Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Manual idle adjuster.  (Read 15188 times)
Re: Manual idle adjuster.
« Reply #20 on: July 28, 2017, 09:06:05 PM »
Fitted mine today.  If you have small enough hands you can remove the throttle stop screw with a 2.5mm allen and then your fingers.  The manual adjuster is much easier to attach with the nice big knurled end.
Offline itchywheels
  • Bike: XT600Z Tenere
« Reply #21 on: July 28, 2017, 09:28:51 PM »
Some thing else for the shopping list !
Into the great wide open, under the skies of blue. Out in the great wide open, a rebel without a clue !!
« Reply #22 on: July 29, 2017, 08:22:51 PM »
Just for variety I remounted the stepper 90 degrees clockwise using as the anchor point it's lower mounting plate mount.  Some locktite on the screw and all good.  The actual roller mechanism I rotated so the roller is uppermost & zip-tied it there.
Offline Seanocaoimh
« Reply #23 on: April 13, 2018, 08:49:12 PM »
Q for KildareMan I'm told from dealertool that I can't adjust the idle speed. The oil light comes on when I'm at idle so I'm thinking could I fit the manual adjuster and raise the idle enough to get the light to stay off ? It seems an easy enough
Job , reading what people on this thread say about it . I could check the oil sensor at the same time , what ya think.
« Reply #24 on: April 14, 2018, 10:58:47 AM »
As the other thread.  Check / have checked the actual oil pressure.  DO NOT mask the issue by raising the idle with a manual adjuster.  When you are sorted then think about the manual.  I much prefer it as I have a rock steady idle with not hunting at all - something that always bugs me.
Offline Seanocaoimh
« Reply #25 on: April 14, 2018, 11:04:37 AM »
Thanks , will do.
Offline Gasman
« Reply #26 on: May 29, 2018, 09:04:43 AM »
I have just checked the link above and it says no longer available. Is that the case or are the parts still available somewhere?
Offline digger06
  • digger06
  • Bike: tiger 800 xc
« Reply #27 on: June 09, 2018, 08:06:06 AM »
my adjuster was off a honda, the thread etc is quite common , i got mine from a scrappers
« Last Edit: June 09, 2018, 08:09:14 AM by digger06 »
Offline ccmp
  • Bike: 2015 800 xca
« Reply #28 on: June 09, 2018, 08:28:37 AM »
Can anyone tell me what the thread size is? I dont want to go stripping tank etc to find out.
« Reply #29 on: June 09, 2018, 10:27:21 AM »
*Originally Posted by ccmp [+]
If I have the correct bag from my box of bits it's M5 - with a 2.5mm recessed hex and a 7mm lock nut
