Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Anyone adjusted the speedo  (Read 2975 times)
Re: Anyone adjusted the speedo
« Reply #10 on: November 03, 2016, 11:40:48 PM »
Simple question--has anyone here had any success in correcting the speedo reading using the tuneecu feature? I have loaded a correction value in, loaded the tune, but there was no effect on the bike (800XC 2012).
(Please, no comments re:should/shouldn't,  just whether it can be done with current tuneecu android or not)
Hey Chuck. Whats wrong with the cruise control?  :001:
Seriously, did you see @KildareMan post above? Looks like it might not work on the 800.
« Reply #11 on: November 12, 2016, 05:02:34 AM »
I can now confirm using tuneecu with latest Windows version  I can adjust both speedo and temperature with XC and stock can.
 However using tuneecu android (with a Samsung Tab S) and same OBD2 cable these changes do not take effect on re-program
« Last Edit: February 13, 2017, 09:40:30 PM by chuckxc »
« Reply #12 on: February 13, 2017, 09:41:13 PM »
Update: reminder...if you set a speedo correction %age into the ECU your speedo will read accurately, but the compromise is your odometer will be inaccurate by the same %age.
