Can someone update on making the blueprints for raising the fender with 15mm? Is it true that if you raise it more you will have issue with the radiator?
Not the radiator. The risk is that it hits the bottom Yoke on full bump. Touratech do (or used to) a kit to raise it just the right amount.
