Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Clutch Centre Nut & Washer Replacement  (Read 1176 times)
« on: January 26, 2017, 05:31:31 PM »
I'm about to order the parts I need to re-install the clutch basket but can't quite figure out what parts need or may need replacing.
The manual only mentions replacing the Belleville washer and re-using the nut but I'm sure I'll need a new nut if the original has already been staked?
Can anyone clarify?
Also, is the Belleville washer part number 24 on this drawing? it's not clear
Re: Clutch Centre Nut & Washer Replacement
« Reply #1 on: January 26, 2017, 06:37:53 PM »
Can anyone clarify?
Well, whilst not having done a T800 clutch - personally - I have seen many a clutch innards.
So, yes.
By no other reasoning than part# 24 costs 2 ~ 3 times more than part# 25 (as well a dome-shaped Bellville washer should -- over a common 22x34 flat washer).
Well, you probably wouldn't be the first one to re-use a clutch nut?
If the manual doesn't say "replace"? -- then it's a judgement call. It's only money, after all -- and, the nut costs less than that fancy washer...  :033:
  • Bike: Moto Guzzi V7850
« Reply #2 on: January 26, 2017, 08:14:18 PM »
I re-used my nut only because the dealer hadn't previously staked it when doing the return spring bulletin.  So I have a nut ready and waiting.
Moto Guzzi V7 Centenario baby!
« Reply #3 on: January 26, 2017, 08:35:03 PM »
Thanks for the info
Yeah, I've re-used clutch centre nuts in the past, it was just that I hadn't actually laid eyes on the Tiger one (& the manual not mentioning re-using it) so wondered if it was any different
cheers
