Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: BATTERY CHARGING VIA DIN SOCKET  (Read 3131 times)
Offline TigerNige
Re: BATTERY CHARGING VIA DIN SOCKET
« Reply #20 on: November 05, 2018, 09:35:49 AM »
My 2012 800 road, handlebar and side sockets both live. I find the simpler Optimate 2 does the job quite nicely  :001:
« Reply #21 on: November 05, 2018, 10:23:27 AM »
 :0461: Like ^^^he said, get the optimate 2 which comes with the fused battery connection lead. Lots of sellers on ebay or Sportsbikeshop is usually competitive & better if you get a problem with it.
https://www.optimate.co.uk/products/optimate-2
Offline Rogue_Shadow
  • Bike: XRT
« Reply #22 on: November 05, 2018, 11:48:55 AM »
Probably over complicating things trying to charge through the HELLA, when a Optimate plug would just as easy.
Thanks for your help all :028:
My next post in this section will be looking how to undo the mess the previous owner did with the Sat Nav.
Teed into the rear socket and spliced into one of the relays/ fuses  :138:
Offline TigerNige
« Reply #23 on: November 05, 2018, 01:28:55 PM »
I actually find the DIN plugs more convenient to plug into. Optimate do straight forward adapter leads to connect the din plug to optimate plugs ( be careful as there are 2 optimate leads the old small flat white (Tamia) plugs, and the new black 2 pin connectors), made up my own as its a bit cheaper than Optimates 17 odd.  :028:
Offline Earl
  • Bike: Tiger 800 xc
« Reply #24 on: November 06, 2018, 12:04:49 PM »
I made up an adapter from my optimate style charger to the mini din plug works fine
« Reply #25 on: November 08, 2018, 11:31:04 PM »
I use whichever of the two Hella sockets is most convenient for the charger (a CTEK). I prefer that to having bits of wire dangling around the place.
