Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Suspension work  (Read 2657 times)
Offline mbay
  • Bike: Tiger 800 XC
Suspension work
« on: May 28, 2017, 09:20:45 AM »
I've decided to get me some progressive springs in the front and have some questions.
Is it hard to do the work by myself?
What parts except the springs do i need to order?
How much oil is recommended in the forks? And what type?
For your info I'm changing to WILBERS Zero Friction springs.
Best regards!
Offline Burt
  • Bike: Tiger 800 XCX
Re: Suspension work
« Reply #1 on: May 28, 2017, 09:48:54 AM »
*Originally Posted by mbay [+]
Best regards!
I seriously think you should ask all those question to the people/company you are purchasing the spring from. After all, they make the conversion and hopefully they should know what the job entails too...
Offline Turbo100
  • Bike: 17 Tiger 800 XRt
Re: Suspension work
« Reply #2 on: May 28, 2017, 10:52:48 AM »
*Originally Posted by Burt [+]
Good question Mbay, this is what this forum is all about....getting info from people that have done it.
The seller might say it's a job for them to do, making more money from them and it could well be a 1 hours easy job you could tackle yourself.
Offline Burt
Re: Suspension work
« Reply #3 on: May 28, 2017, 12:05:58 PM »
Again, if I buy a specific kit from a company I would definitely ask them if I need any extra part or any other infos to finish the job properly, instead of relay on forum speculations... I never said he shouldn't try the job himself...
Offline mbay
Re: Suspension work
« Reply #4 on: May 28, 2017, 12:59:23 PM »
I want to do the job by myself, just so i learn how all with my bike works.
I'm just wondering about the parts i need, like dust seal and so on.
And how much airgap/oil in my fork i need.
Well, I'm gonna ask my dealer but i also wanted input from the riders here who actually uses the bikes after the installs.
They may have an other opinion of how much oil/things i need.
Offline Gasman
Re: Suspension work
« Reply #5 on: May 28, 2017, 03:48:48 PM »
I have not used progressive springs on my Tiger but I have used the progressive Wilbers on my TDM. It's an easy install but I have found them to be a little more firm than the OE ones.
Offline mcinlb
  • Bike: 2013 Tiger 800
Re: Suspension work
« Reply #6 on: May 28, 2017, 04:36:00 PM »
Bought exactly the same from Wilbers, no additional parts required, 1 ltr bottle of 5W fork oil to do the job as recommended by Wilbers.
Going to change them in the next few days, relatively straight forward job.
https://www.wilbers-shop.de/en/Motorcycle/Triumph/Tiger-800-A08/Promoto-Forkspring-progressive.html?cur=1?manufacturer=amu0b816a037e22937fc2aa2f9d471bb&year=2013&catname=ac33d4511e261857920adf39d30ecfdf
Offline mcinlb
Re: Suspension work
« Reply #7 on: May 30, 2017, 02:41:58 PM »
Fitted the Wilber progressive springs with 5W oil, still to test, weather is crap.
Springs were slightly longer than the standard, 25mm - 30mm, made it a bit awkward to get the fork tops back on..
Managed it but a second man would have made it much easier......
Going on a weekend trip on Friday, will report back after..... :002:
Offline Burt
Re: Suspension work
« Reply #8 on: May 30, 2017, 11:19:23 PM »
Unless like some website, they use one picture for similar products, the link above doesn't seem to be the picture of a progressive spring, or at least not a spring with much progression in it...
Normally the coils have a much greater variation from top to bottom...
Offline mcinlb
Re: Suspension work
« Reply #9 on: May 31, 2017, 08:45:28 AM »
Yes, bad photo, they were definitely progressive in design.......  :002:
