Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2017 XCX Cruise Control  (Read 7940 times)
Offline midwesttrekker
  • Bike: '17 800 XCx
« on: June 13, 2017, 06:55:25 PM »
I've had my '17 XCX for 10 days and haven't been able to get the Cruise control to work.  The switches are a little different than last year; the Hazard Flashers button is where the Cruise Control "on" button used to be.  According to the Owner's Manual (RTFM, right?) it says the Set button turns it on.  But, not for me.  And yeah, I've made sure I have been in 4th gear or higher, and well over 30mph when I've tried it.  No ABS light or anything else that would cause it not to work.
Thoughts?
- Galen
« Last Edit: June 13, 2017, 06:56:57 PM by midwesttrekker »
Online Kerryman
  • Bike: Tiger xrx
Re: 2017 XCX Cruise Control
« Reply #1 on: June 13, 2017, 07:09:12 PM »
Haven't used my cruise control for awhile,but as far as I can remember you push in set button, than toggle the switch up or down.
Offline Turbo100
  • Non-Active
  • RIP
  • Bike: 17 Tiger 800 XRt
« Reply #2 on: June 13, 2017, 08:02:04 PM »
Contrary to what is says in the manual where you press the bottom right hand corner that says "SET" you have to press is twice in quick succession, that energises the CC and the green light with come on your clock display. You then press the + and - to select the speed you want it at from the display just below the MPH reading
  • Bike: '17 800 XCx
« Reply #3 on: June 13, 2017, 08:53:35 PM »
Thanks Turbo! I'll try it.
Offline Turbo100
  • Non-Active
  • RIP
« Reply #4 on: June 13, 2017, 09:04:04 PM »
You can disengage CC by momentarily applying front or rear brake, pulling the clutch in and the way I use is rolling the throttle off past its natural neutral position, if you try it there is a minute remaining travel of the throttle that if you apply a little pressure you will feel it.
  • Bike: '17 800 XCx
« Reply #5 on: June 13, 2017, 09:42:44 PM »
Tried the 2 quick presses and still no luck.  Seems to me like it's broken, or computer needs to be flashed.
Offline Turbo100
  • Non-Active
  • RIP
« Reply #6 on: June 13, 2017, 09:47:57 PM »
What speed were you doing, you have to be higher than a certain speed and in 3rd gear + if my memory serves me right. It tell you in the manual, if all is as should be and still no go, well that sounds like a trip to the dealers
  • Bike: '17 800 XCx
« Reply #7 on: June 13, 2017, 09:51:19 PM »
I tried several times at speeds > 45mph in 5th and 6th gears.
Offline Turbo100
  • Non-Active
  • RIP
« Reply #8 on: June 13, 2017, 09:53:20 PM »
Dealers unfortunately :191:
Offline Garjam
  • Bike: 800 XCX
« Reply #9 on: June 14, 2017, 03:29:27 AM »
On my 15 yr model xcx there is a separate 'on' button that u must press first. It has an icon like a litle clock face on it .  Once i do that i hit set n away she goes.  This may not help u but just puttin in my two cents.  U have a  new bike so ur sweet with repairs should it turn out thats whats required.  Good luck with it.
