Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2017 XCX Cruise Control  (Read 9980 times)
Offline Bladerunner99
  • Bike: 2018 XCA
Re: 2017 XCX Cruise Control
« Reply #40 on: June 27, 2017, 10:12:42 AM »
Would anyone happen to know if this reset sequence would rectify speed/CC setting discrepancies.  My 2015 XCX never travels at the speed I set via the CC, always 1 or 2kmh lower.  I recently rode a 1200 Explorer and that was bang on!
Ride to work. Work to ride
Offline chippy
  • Bike: Tiger XRX
« Reply #41 on: January 09, 2018, 08:25:00 PM »
Happy days
Offline EddieCalimocho
« Reply #42 on: July 04, 2020, 11:34:28 AM »
*Originally Posted by midwesttrekker [+]
Hey guys, I got it working.  I had to step through a reset sequence I'll outline below.
This is the switch layout on my 2017 XCX:
Key in off position
Kill switch in [X] (off) posiition
Put bike in Neutral
Sit on bike, kickstand up.
Make sure the CC is off (pre 2017)
Turn on Key
Turn on Ignition (Red lever kill switch on / down)
Green light for CC should be blinking (Mine was anyway)
Start the reset sequence:
Activate the Front Brake Switch by pulling and releasing the front brake
Activate the Rear Brake Switch by pressing and releasing the rear brake pedal
Activate the Clutch Switch by pulling and releasing the Clutch
Activate the Twist Grip Cruise Control cancel switch by operating and holding the throttle grip in the fully closed position
Press the Cruise Control On/Off switch to ON (on the 15, +/Accel switch on '17)
Press the Cruise Control +/Accelerate Switch
Press the Cruise Control -/ Decelerate Switch
CC light should stop blinking
Since I did that, I've had perfectly functioning cruise control.
Just want to say thanks for posting this, as this restored my cruise control this morning.
After some issues with clutch I was scratching my head this morning as cruise control pin seemed engaged fine and then turned to this forum.
Worked like a treat and will DM to say thanks too 👍
Offline casimiro
  • Bike: tiger 800 17
« Reply #43 on: February 27, 2021, 03:59:57 PM »
image now dead
Key in off position
Put bike in Neutral
Turn on Key
(I use google translator)
Thank you very much for your information and help.
The error P1575 of my motorcycle is solved thanks to your instructions.
Thank you.
Greetings from Spain
