Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: front end bounce  (Read 79533 times)
Offline blacktiger
  • Bike: Tiger955i&800XC
Re: front end bounce
« Reply #500 on: March 24, 2017, 07:17:32 PM »
*Originally Posted by XS904 [+]
If you don't mind me asking, what did they change & what was the cost?
Rob
My Maxton internals cost 426 all in. That's cartridges, springs and oil.
Black '13 Tiger800XC. The other British Land Rover. 19000 miles and counting.
Black '02 Tiger955i, 72K and counting.
Offline Trotters
  • Ex Member
  • Bike: Tiger ABS
« Reply #501 on: April 24, 2017, 09:28:17 PM »
 :084:  I can't decide whether to tell you about my 2013 800ABS that has no bounce coz it might put the mockers on it!
So l won't!............................... :015:
Mick
Offline alexnyc
  • Bike: 800 xc
« Reply #502 on: September 13, 2017, 05:58:19 PM »
Hi all ,
As my '11 xc is suffering from the bounce as well ..: since its first tire change (10k miles) and I tried quite a few things .
- 5w oil . Helps a bit but made the front end feel vague and dives when on the brakes .
- balancing gel in the tubes . Also helped bit not a cure .
-tire pressure?? Why would it have such an effect after 10k miles if it didn't for the first 10k??.. I ride for 30 years and never saw modest pressure variations have such an pronounced effect on a bike .
After reading this thread I decided to have the fork internals upgraded
I'll have orient express in Long Island -NY put K tech 20mm cartridges and they said they could work on rear shock   as well . Not sure what they'll do but I'll let u know  once I have info.
I'll update once the work is completed ( 2 weeks as I'll be gone for a while !)
Also they noticed that my front tire is full of ripples ( Karoo 2) they said that it's clear the suspension is out of sync . These are classic symptoms, uneven wear etc ...
I hope it will solve this issue as the bike is great but this suspension is really unacceptable, I have developed a fear or comers !!! They are the reason to drive on 2 wheels!
Anyway I hope to be able to give some positive updates once installed.
Have fun out there.
Offline alexnyc
  • Bike: 800 xc
« Reply #503 on: October 11, 2017, 04:28:08 AM »
Some updates!!
The k-tech cartridges have been installed.. incredible difference but first .
My upper triple clamp had a crack ?
Seriously how bad is the casting process at triumph?
Now I know why my bike felt weird, shacky ...etc
Well know the good things , all new parts fitted and the K-tech cartridges at orient express on Long Island ( they are top guys if you need help around NYC)
The front feels right and heavy, not in a bad way , as holding the ground properly.
And the bounce as far as I can feel has been eradicated!!  :123:
I'm super happy I could fix this very annoying issue as I was about to get a new bike
But I really like this machine and I'll keep it now .
They set the suspension at standard for now , I can dial it in if needed but if feels correct for on road with my weight (165)
I was going to get the anderani kit originally but I'm glad I went with this  set and that it was installed but not only pro guys but they really care about their stuff . Really impressed with these guys
Offline fac191
  • Bike: Super Tenere ES
« Reply #504 on: October 11, 2017, 07:32:12 AM »
Mine split right through and I had it replaced by the dealer. I can't remember if it was still under warranty.
« Reply #505 on: October 11, 2017, 12:56:01 PM »
Playing devils advocate here.  How do you know it's a Triumph issue (the crack)?
Stupid is as stupid does.
IRL via GB & CL
Offline alexnyc
  • Bike: 800 xc
« Reply #506 on: October 12, 2017, 05:36:17 AM »
true .. I do not know who casts their triple clamp ! I was just being optimistic, I guess
But it looks like a manufacturing issue . Low quality welding, bolts not sitting flat ...
I know I didn't hit anything that would crack it or I'd remember!!
I tried attaching pics but they are too big !!
Anyway I'm still super happy with the results
Offline alexnyc
  • Bike: 800 xc
« Reply #507 on: October 12, 2017, 05:37:48 AM »
Actually it worked :020:
