Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Screwed  (Read 2893 times)
Offline RoadWarrior
  • Ex Member
Re: Screwed
« Reply #10 on: July 11, 2017, 01:29:08 PM »
YOU  :123:
Offline skinneroo
  • Bike: tiger road
Re: Screwed
« Reply #11 on: July 11, 2017, 06:00:59 PM »
*Originally Posted by odum666 [+]
I suppose you don't need a sense of humor with a pretty face. The only trouble is though, Missy, if you should lose the face.
 :002:Correct.
I used to rate MadMax 2 as the best, but now,although it's a bit of a 'B' movie,I rate 1 more highly.  :451: :431:
Offline RoadWarrior
  • Ex Member
Re: Screwed
« Reply #12 on: July 11, 2017, 09:26:24 PM »
I always felt the first one had the better story and characters.
Who knew that the actor Hugh Keays-Byrne who played the Toecutter also played Imortan Joe in Thunder Road.
Offline CliffJ
  • Tiger 800- 32k miles in saddle and counting!
  • Bike: Tiger 800 ABS
Re: Screwed
« Reply #13 on: July 22, 2021, 04:23:36 PM »
Rear brake pad pin jammed, just as described above - no doubt done over tightened by mechanic at full service (36k) - non Triumph, hex hole damaged. Took it back and he tried Torx trick, no joy! Now booked in for calliper to come off on bench to drill it out no doubt!! Grrr! Tiger 2014
Ex Honda CBF1000, Ex Honda Hornet 600.
