Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Fog light bulbs  (Read 477 times)
Offline dunkymunky
  • Bike: 2011 Tiger 800XC
Fog light bulbs
« on: August 12, 2017, 04:49:11 PM »
Anyone know the specs of the oem fog light bulbs? Or where I can get them? 1 of them has blown:(
Offline The Reaper
  • Bike: 800 XRX
Re: Fog light bulbs
« Reply #1 on: August 12, 2017, 06:08:36 PM »
Isn't it a sealed unit, and therefore you need to replace the whole light? 🤔
Offline dunkymunky
Re: Fog light bulbs
« Reply #2 on: August 12, 2017, 06:10:18 PM »
You can definitely get in to It, there are two screws on the back that if you undo, then lens can be removed
Offline The Reaper
  • Bike: 800 XRX
Re: Fog light bulbs
« Reply #3 on: August 12, 2017, 06:15:50 PM »
No idea then, hopefully someone more knowledgeable will come along soon to enlighten us! 🙂
Re: Fog light bulbs
« Reply #4 on: August 12, 2017, 06:35:45 PM »
55W H3, I believe
Offline healdem
  • ....has a fluffy tube
Re: Fog light bulbs
« Reply #5 on: August 12, 2017, 06:44:28 PM »
but they are an odd fitting... do a search on dilbverts posting on this subject.
Offline T800XC
  • Bike: 800XC & Explorer
Re: Fog light bulbs
« Reply #6 on: August 12, 2017, 07:35:55 PM »
I think the fitting's OK but didn't they have a narrow spade terminal (1/8"?) as opposed to the more common 1/4"?
I've got some Osram PK22S H3 lamps for mine and it's possible to just change the terminal to suit.
Offline TigerNige
Re: Fog light bulbs
« Reply #7 on: August 12, 2017, 08:51:57 PM »
Put Osram Night breakers in mine - Cut the spade terminals down with my dremel. A bit tight on the hole in the middle of the spade, but had enough contact not to get any problems.  use them quite a bit.
« Last Edit: August 12, 2017, 08:54:56 PM by TigerNige »
