Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
April 13, 2021, 06:36:44 PM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Alternative Regulator Rectifiers for 800XC
Print
Pages:
1
2
3
4
6
Go Down
Author
Topic: Alternative Regulator Rectifiers for 800XC (Read 10790 times)
Snownorge
and 7 Guests are viewing this topic.
tomcat
Tiger Pro
Bike: Tiger 800
Re: Alternative Regulator Rectifiers for 800XC
Reply #10 on:
April 25, 2018, 05:27:57 PM »
Mmm, similar situation with my 2013 800r.
Price quoted for fitting a replacement at dealer. £370!
My bike had inexplicably switched off when slowing down through the gears on 3 occasions recently.
To restart, the ignition required switching of then back on to fire up.
When serviced today at the dealers, I mentioned the cut outs and the teccy noticed a pulsating headlight beam.
A check across the battery terminals displayed a pulsating charge rate from 13 to 18v.
Investigations show the reg/rec to be a common item used on a number of manufacturers bikes.
I've sourced a replacement for £35. I'll report again once I fit the replacement.
Logged
Londonglide
Tiger Pro
Bike: xc
Reply #11 on:
April 25, 2018, 07:54:34 PM »
I get the impression a major contributing factor is heat, and the threads suggests that the location of the R/R on the Tiger is better for heat dissipation.
I wonder if you do commuting, or the ambient temp i your neck of the woods is higher than average?
The original FH012aa is replaced by the FH020aa anyway.
Ensure your connections are not burnt or discoloured before reassembly and lube/protect with your choice of product, as discussed on the forum with regard to general electrical connections.
Good luck.
I never got round to fitting mine yet. trying to decide if I can release the rusty rad mounts without damaging anything.
Logged
tomcat
Tiger Pro
Bike: Tiger 800
Reply #12 on:
April 25, 2018, 08:34:16 PM »
My Tiger isn't a commuting bike. Mainly longer runs.
I've covered about 17,000 miles in 4 years on her.
I reside on the Lancashire/Yorkshire border, so hardly tropical.
I don't suppose siting the reg/rec behind the radiator and directly above the exhaust header pipes aids temperature!
The expired reg/rec on my bike is the later 20AA version.
Last Edit: April 25, 2018, 08:37:11 PM by tomcat
Logged
lparker1983
Tiger Pro
Bike: 800 ROADIE 2012
Reply #13 on:
April 25, 2018, 09:55:18 PM »
Whats the difference in the aa reg recs compared to the ab ones?
Logged
tomcat
Tiger Pro
Bike: Tiger 800
Reply #14 on:
April 28, 2018, 12:29:35 PM »
My replacement reg/rec was delivered today.
Fitted, working, output tested at battery terminals and delivering a nice steady 14.5 volts.
If you need a replacement at any stage, use the part number stamped on the base of the reg/rec, not the
triumph part number.
Mine is a FH020AA, sourced through a Yamaha outlet. just under £36 inc' delivery.
Superb timing as the Tiger and I are booked on the ferry to Dublin this next Thursday.
Last Edit: April 28, 2018, 12:32:18 PM by tomcat
Logged
lparker1983
Tiger Pro
Reply #15 on:
April 28, 2018, 05:15:19 PM »
What year is your tiger? I'm on a 2012 and my part is fh012ab
Logged
Stevie.P
Tiger Jedi
'Arte et Marte'
Bike: 2015 Tiger XRt
Reply #16 on:
April 29, 2018, 12:41:00 PM »
Originally Posted by
tomcat
... the teccy noticed a pulsating headlight beam.
Noticed the same last set of shifts at 9pm when starting bike in the bike shed in works car park. As I have just removed seats to remove battery to access rear wheel sensor to investigate MIL, ABS & T/C fault lights permanently on, I thought with the above post in mind, I would check my battery/charge.
Engine off ...
... and at tick-over.
Really starting to despair at the issues this bike has had, more failures in 2.5yrs than my 39yr old T140 Bonneville and 6 months out of warranty.
Time to cross check the XRt part number against the other models and if cheaper Yamaha replacement viable?
Logged
lparker1983
Tiger Pro
Reply #17 on:
April 29, 2018, 12:45:09 PM »
Yep deffo reg rec failure there. I always thought the FH series units were reliable.
Logged
Stevie.P
Tiger Jedi
'Arte et Marte'
Reply #18 on:
April 29, 2018, 12:58:04 PM »
Hopefully the static voltage indicates I've caught it before frying the battery .... if I have to add a battery to the current expenses I will be even more pi**ed off than I already am ... and that's without any more expense the warning light issue might bring.
Logged
Rtwo
Tiger Jedi
Bike: KTM 1290 SAS
Reply #19 on:
April 29, 2018, 01:00:15 PM »
IMO, it's worth fitting some sort of monitor, cheap enough so a no brainer for me
https://www.ebay.co.uk/itm/200609174686
Logged
Print
Pages:
1
2
3
4
6
Go Up
Newbie
New Members
Stelyn
Today
at 06:19:29 PM
I gave my Tiger a new look
Roger S
Today
at 05:51:32 PM
Might be a silly thought - Security
awjdthumper
Today
at 05:49:23 PM
Vibrating chain guard on acceleration
awjdthumper
Today
at 04:30:38 PM
Hello from India
New Members
tauzero
Today
at 03:32:49 PM
900 GT Pro Suspension Prelaod
Ian P
Today
at 12:26:09 PM
Planning Cape York (Aust) mid 2022. How to prepare and what 'could I break'
Off-Road and Trail Talk
K1W1
Today
at 08:09:16 AM
Removing the Ugly Black Box EVAP
Kris
Today
at 04:18:22 AM
Fitting factory TPMS sensors
Tyres and Wheels
Skeet
Today
at 12:42:38 AM
Debesys
Yesterday
at 09:00:22 PM
