Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Any Scottoiler Experts? V System valve won't release.  (Read 505 times)
Offline Jay2
« on: October 11, 2017, 05:33:48 PM »
As per title, my Scottoiler has stopped working, I've got the V System and had all the pipes off and cleaned them out and taken out any kinks in the lines.
But it seems the problem is with the valve inside the big plastic tube, it won't release when the bike is running.  Is this something I can take apart or sealed?  The line to the engine is still securely attached.  Or is there some other problems with the system?
Any help appreciated, as I found it quite handy during crappy weather for keeping my chain clean.
Jay
Re: Any Scottoiler Experts? V System valve won't release.
« Reply #1 on: October 11, 2017, 05:46:10 PM »
The guys at Scottoiler are brilliant, give them a call
« Reply #2 on: October 12, 2017, 10:32:38 AM »
If the valve won't lift my 1st thought is lack of vacuum to actually lift.  If you pull tubing off and use a syringe or just suck on the black tubing coming from the top of the reservoir can you see the valve lift?  To make it easier turn the adjuster for max flow.
Stupid is as stupid does.  Look Dad... No hands!!
Offline Jay2
« Reply #3 on: October 12, 2017, 04:18:23 PM »
Cheers,
Will try 'sucking' and see what happens, hope the Mrs isn't watching as she thinks I already spend too much time alone with the bike.  :034:
Offline Turbo100
  • Bike: 17 Tiger 800 XRt
« Reply #4 on: October 12, 2017, 07:25:45 PM »
*Originally Posted by Jay2 [+]
Cheers,
Get the wife to do it, she could well be better at it than you  :038:
Offline viince
  • what if the hokey cokey is what it's all about
  • Bike: tiger 800
« Reply #5 on: October 12, 2017, 10:08:30 PM »
Cheers,
*Originally Posted by Turbo100 [+]
thanks  :152:
PSML and just spat my tea all over the screen  :123:
as above found the people at scot oiler to be extremely helpful   :188:
cheers vince  :031:
« Last Edit: October 12, 2017, 10:11:38 PM by viince »
