Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: What spark plugs, 13 800  (Read 2330 times)
Re: What spark plugs, 13 800
« Reply #10 on: December 07, 2017, 09:41:14 AM »
My NGK Iridium's have been in for over 5 years now.
Stupid is as stupid does.  Look Dad... No hands!!
Offline street tango
« Reply #11 on: December 07, 2017, 12:05:24 PM »
If doing your own service don't forget the shock linkages.
Offline benebob
  • Bike: 13 800 ABS
« Reply #12 on: December 07, 2017, 02:05:01 PM »
*Originally Posted by street tango [+]
You mean lubing 'em up with anti seize and grease right?
« Reply #13 on: December 07, 2017, 02:09:01 PM »
*Originally Posted by benebob [+]
Yes lube the needle bearings, bushings etc.
Offline benebob
  • Bike: 13 800 ABS
« Reply #14 on: December 07, 2017, 02:11:36 PM »
Biggest problem I've found with long life plugs is with plugs mating to the head with the use of different metals.  When I did my XJR at 60k on the original plugs I had to gently work 'em out as to not rip a thread or two.  I shutter to think what would have happened with your average parts replacer at 90k which I believe was the service life from factory.  I have zero problems replacing 'em per the schedule, what irks me more is manufacturers doing away with hyrdraulic lifters in favor of shims.  It does keep dealers in the money though but to me if I gotta take the plugs out anyways to do the valves, might as well put new ones in and throw the others in my oh s&^@ emergency bag.
Offline benebob
  • Bike: 13 800 ABS
« Reply #15 on: December 07, 2017, 02:14:22 PM »
Yeah, I just had everything off back there last winter as I replaced my swingarm thanks to the dealer who serviced the bike before I bought it and Triumph for not knowing what antiseize was so my one chain adjuster was seized.  Found a used swing arm cheaper then doing thru the process of drilling and retapping.
« Reply #16 on: December 07, 2017, 02:17:43 PM »
That's another job that should be done or better replace with stainless, but still need lube. you can sprey chain lube up through the drain holes now and again too.
Offline benebob
  • Bike: 13 800 ABS
« Reply #17 on: December 07, 2017, 02:21:00 PM »
I actually closed the drain holes up with some mastic.  Didn't have stainless bolts when I did it but when I replace the chain over the winter I have 'em now and yeah they will be lubed up good.
« Reply #18 on: December 07, 2017, 02:26:49 PM »
Mine come out per the schedule for a breath of fresh air and some anti seize on the threads.  Then back in for more spanking.
Offline benebob
  • Bike: 13 800 ABS
« Reply #19 on: December 07, 2017, 02:31:11 PM »
Yes and you are taking 'em out every year or so to do your valves, not every 5-8 like most vehicles with long plugs.  For me I can get 10 of the copper plugs for $14 shipped or I can get 3 of the Iridiums for $32 shipped so replacing 'em with copper knowing they will be out again in about a year is cheaper.
