Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Kaoko with Barkbusters and Oxford Heated Grips  (Read 283 times)
Offline becsta
  • Gender: Female
  • Bike: 2014 Tiger 800
« on: January 13, 2018, 05:19:38 AM »
Today I tried to install the Kaoko throttle lock. I have Oxford heated grips and Bark Busters on my bike. I have run into some problems so was hoping others that have installed it can help.
The grips hang a fair bit past the throttle tube so I cut it back.
But when putting the Kaoko on I have a big gap.
Offline Psychopasta
  • Gender: Male
Re: Kaoko with Barkbusters and Oxford Heated Grips
« Reply #1 on: January 13, 2018, 06:26:14 PM »
Looks like the grip was cut back a bit too much, and you need a shim of some sort to fill out the space.
Offline becsta
  • Gender: Female
« Reply #2 on: January 13, 2018, 08:10:38 PM »
The instructions said the plastic washer has to press against the throttle tube and not the rubber so I had to cut it that much for that to happen.
Offline becsta
  • Gender: Female
« Reply #3 on: January 16, 2018, 11:55:09 PM »
So I got my Kaoko installed. Sometimes it really does help to read the instructions  :156:. It says that in some cases you may need to move the throttle towards the outside of the bar, once I did this all was good.
Offline Psychopasta
  • Gender: Male
« Reply #4 on: January 17, 2018, 04:18:45 AM »
Yay!  :046: :047:
