Tiger 800 XRT/XCA Wiring Diagram KeyKey Item Description1 Instrument Assembly2 Front Brake Switch3 Engine Stop Switch4 Start Switch5 Engine Electronic Control Module6 Oxygen Sensor7 Oil Pressure Switch8 Ground9 Coolant Temperature Sensor10 Crankshaft Position Sensor11 Purge Valve12 Injector 313 Injector 214 Injector 115 Fuel Level Sender16 Fall Detection Switch17 Intake Air Temperature Sensor18 Ambient Air Pressure Sensor19 MAP Sensor20 Gear Position Sensor21 Heated Grips22 Left Hand Heated Grip23 Right Hand Heated Grip24 Engine Electronic Control Module Relay25 Accelerator Position Sensor26 Secondary Air Solenoid27 Fuel Pump Relay28 Throttle Position Sensor29 Fuel Pump30 Coil 331 Coil 232 Coil 133 Cooling Fan Relay34 Cooling Fan35 Right Hand Switch Housing, Twist Grip, Cruise Control Cancel Switch (8 Pin Connector)36 Side stand Switch37 Ride by Wire Motor38 Right Hand Switch Housing (16 Pin Connector)39 Diagnostic Connector40 Rear Brake Switch41 Rear Brake Switch Relay42 Rear Right Hand Direction Indicator43 Rear Light44 Rear Left Hand Direction Indicator45 Alarm46 Starter Motor47 Starter Solenoid48 Battery49 Regulator/Rectifier50 Alternator51 Starter Relay52 Fuse Box (Rear)53 Fuse Box (Front)54 Rider’s Heated Seat55 Passenger’s Heated Seat56 Heated Seats Switch57 Immobiliser and TPMS Control Module58 Ignition Switch59 Headlight Relay60 Clutch Switch61 Horn Switch62 Scroll Switch63 Select Switch64 Direction Indicator Switch (Right Hand)65 Direction Indicator Cancel Switch66 Direction Indicator Switch (Left Hand)67 Pass Light Switch68 Headlight Switch69 Rear Wheel Speed Sensor70 Front Wheel Speed Sensor71 ABS Modulator72 Accessory Socket 373 Accessory Socket 274 Accessory Socket 175 Front Left Hand Direction Indicator76 Left Hand Headlight77 Right Hand Headlight78 Sidelight79 Horn80 Front Right Hand Direction Indicator81 Ambient Air Temperature Sensor82 Left Hand Fog Light83 Right Hand Fog Light84 Fog Light SwitchKey To Wiring Colour CodesCode Wiring ColourB BlackU BlueN BrownG GreenS Slate/GreyO OrangeK PinkR RedP PurpleW WhiteY YellowLG Light GreenLU Light Blue
Go Up
