Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: chain and sprockets - wheres cheapest  (Read 1288 times)
Offline hoggyf
  • Bike: tiger 800 roadie
« on: January 27, 2018, 03:41:59 PM »
Need a new chain and sprockets for my 2011 roadie as chain has a tight spot in it (loads of life left otherwise  :023:) so any recommendations other than the dreaded ebay? Best I've seen is DID for around 87.00
Offline Turbo100
  • Bike: 17 Tiger 800 XRt
Re: chain and sprockets - wheres cheapest
« Reply #1 on: January 27, 2018, 10:30:26 PM »
This is an OK dealer, used him many times, I usually collect from him only 7 miles away
http://www.squaredeals-ltd.co.uk/chains--sprockets-tiger-800--800xc-786-c.asp
Offline Rogue_Shadow
  • Bike: XRT
« Reply #2 on: January 28, 2018, 12:10:20 PM »
Ive always used Wemoto for chains  :028:
Awesome for loads of other bike parts too.
http://www.wemoto.com
« Last Edit: January 28, 2018, 12:12:04 PM by Rogue_Shadow »
Offline hoggyf
« Reply #3 on: February 07, 2018, 09:11:09 AM »
Chain and sprockets bought, shame the bloody front sprocket is stuck on, 2 ft breaker bar won't shift it so lets hope the impact driver I'm borrowing does the trick!
Offline Turbo100
« Reply #4 on: February 07, 2018, 09:22:59 AM »
*Originally Posted by hoggyf [+]
Personally I wouldn't use an impact driver, possibility of damaging the internal gearbox gears.
Usually the nuts are finger tight, mine was and reports of them coming off whilst riding  :114:
Offline troubleshooter
« Reply #5 on: February 07, 2018, 10:23:04 AM »
I needed a breaker bar with an extension - soak the nut threads in PlusGas or similar overnight
Offline Turbo100
« Reply #6 on: February 07, 2018, 10:49:54 AM »
Don't put WD40 on its not up to the job, plusgas like has just been said, get someone to give you a lift, stick it in 6th and rear brake on hard, 6 sided socket, 2 foot bar,  the nut will relent don't worry
Offline Blackbeard
  • TigerBaws.blogspot.co.uk
  • Bike: Tiger 800 XC SE
« Reply #7 on: February 07, 2018, 12:18:36 PM »
Personally I wouldn't use an impact driver, possibility of damaging the internal gearbox gears...
Curious, how so?
Offline hoggyf
« Reply #8 on: February 07, 2018, 01:05:57 PM »
its been soaking in Rost free stuff that my local bike shop uses, deffo no WD40 or similar here!! Rattle gun is the last option TBH, big long bar tonight and someone to help is the plan.
  • Bike: 2016 Tiger XRt
« Reply #9 on: February 07, 2018, 03:19:31 PM »
When I have really tight stuff like this i.e car main hub nuts I use a long (12") extension on the socket and set up an axle stand to support the outer end of the extension instead of holding it making it easier to then use the T bar on the end and stand on it (in excess of 200ft/lbs  :164: :008: ).
