I’m a bit late to this party here but I have just fitted a sat-nav bracket made by forum member Mike on a Bike to my XCA and am really pleased with it
It's much easier and safer to see my sat-nav now just above the instruments than down on the bars where it was before.
As stated earlier in this thread by Mike some finishing off is required as the bracket is supplied as is, strait from the casting.
I used a file followed by an emery wheel on a drill to smooth off and then drilled the necessary 3 holes, one 6mm & two 8mm.
Finally I painted it black with a spray can of Hammerite Semigloss Black. (don't try this in the garage, it really is best done outside!)
To mount my TomTom clamp to the bracket I used this 1” RAM ball which has a M6 female thread found on ebay here:
https://www.ebay.co.uk/itm/Genuine-RAM-B-273-M6-1-Ball-with-M6-Threaded-Hole/122401564775?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2648And attached it to the bracket with a 16mm M6 Button Head bolt.
Two 25mm M8 Button Head bolts with Flanged Locknuts were used to attach the bracket to the fairing mount.
I believe Mike might still have a couple more brackets left should anyone else be interested in one.
But I don’t think he’s planning on casting any more, so if you like the look of this bracket, get one while you can!
You can contact him via private message on these forums.
Once again thank you Mike
