Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Center stand problem  (Read 3174 times)
0 Members and 5 Guests are viewing this topic.
Online Alunr
  • Alun
Re: Center stand problem
« Reply #20 on: September 17, 2018, 11:57:30 AM »
@dasf - Really neat looking solution. Kudos  :493:
You're never too old to have a happy childhood :-)
Past Bikes: Panther 600, BSA Bantam, Lambretta TV 175, Lambretta GT200, AJS 125, Suzuki Gladius, Honda NT700. Present: Triumph Tiger 800 ABS
Offline D6864
  • Bike: White XC
« Reply #21 on: September 17, 2018, 12:57:59 PM »
The knack for me is to lift at the pillion peg bracket so I'm lifting in the same upwards and backwards direction as the stand does.  I'm a 65kg weakling and find it quite easy.
Offline thosirl
« Reply #22 on: September 17, 2018, 01:17:48 PM »
I'm the same, find it tough to get the bike up on the centre stand.
I also find it difficult getting it back off the stand - I've got a very smooth garage floor, and when pushing/rocking the bike forward it just wants to scrape/drag along the floor. Need to stand on it and push at the same time. I miss my old CB500X where I could jump up and just lean it forward off the stand, very smooth.
Offline FloridaMarine
  • Bike: 2018 Tiger XRt
« Reply #23 on: September 17, 2018, 03:04:26 PM »
*Originally Posted by thosirl [+]
I also had an issue getting off the center stand on my XRt.  My dealer said to "scuff up" the bottom of the feet with emery cloth/abrasive to cause more friction between the stand and the floor.  Works much better.
Bob
2018 Tiger 800 XRt
1983 Honda GL650
1978 Honda CX500
1973 Honda CB350/F
Offline Gasman
« Reply #24 on: September 20, 2018, 11:50:06 AM »
I snapped my Achilles Tendon putting mine on the centre stand so removed it so I wouldnt try again. I used to put my lowered GS on the stand a little easier.
« Reply #25 on: September 20, 2018, 12:13:29 PM »
Which is the correct way to take a bike off the stand, you have total control
Offline gordybrock
  • Bike: Tiger 800XR 2012
« Reply #26 on: September 20, 2018, 01:52:46 PM »
I always make sure the bike is in gear before I push it off the stand  :002:
I'm from Wigan Me
  • Bike: XC,XCX, CB1300,
« Reply #27 on: September 20, 2018, 10:29:56 PM »
The XC centerstand design is wrong (at least on my 2012 model). The shape does not give enough mechanical advantage (leverage). No technique is going to help.
if you compare it to other MCs you can see the curvature is too sharp and the foot pad is too short.
I have resorted to just using a wooden ramp on the rear wheel and simultaneously thinking about what a sh*# design it is.
Offline gordybrock
« Reply #28 on: September 20, 2018, 11:48:57 PM »
...I have resorted to just using a wooden ramp on the rear wheel and simultaneously thinking about what a sh*# design it is.
I have a 2012 roadie and I have no problem with the centre stand, getting the bike on the centre stand in not about brute strength, it's all about technique. I'm not a big guy, 5ft-6, 11 1/2 stone (160 pounds) and I can throw it on the centre stand dead easy. I used to struggle like hell (blocks of wood under the rear wheel and all that) until I learned the right way. Here's a couple of good tips... when you push the stand down to the floor you MUST have both the feet of the stand on the floor, otherwise you will struggle. Push the bike gently away from you and feel for both the stand feet on the floor, get up close to the bike, bend your knees, grab the frame low down, and just lift up and back. That's how I was taught, I find it easy, it never fails...try it.  :002:
I'm from Wigan Me
Online K1W1
« Reply #29 on: September 21, 2018, 12:13:47 AM »
Sorry but in this case you are wrong. I used to say exactly the same as you and I have owned two Tigers a 14 Roadie and a 16 XRX and I have been putting bikes on centre stands since the early 1970s with no problems. One day @chuckxc got me to try putting his bike on the stand. It is impossible for any mere mortal. There is a fundamental design problem with the stand on some of the early Tigers and that is all there is to it. Whether a particular Tiger can or can't be put on the centre stand is entirely random depending on which stand is fitted.
