Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Low oil pressure light  (Read 40149 times)
Offline Seanocaoimh
« on: April 13, 2018, 04:38:43 PM »
Back again for more advice. The oil pressure light comes on at idle, but goes off again when I in crease the rpm to 2000.
 Any advice ( relevant), appreciated.
Re: Low oil pressure light
« Reply #1 on: April 13, 2018, 04:54:53 PM »
1. check your oil level (@cause it's easy to do)
2. check your oil pressure sensor.
« Reply #2 on: April 13, 2018, 05:35:58 PM »
*Originally Posted by Seanocaoimh [+]
3. check oil pressure w/mechanical gauge: 49 psi @ 5K RPM (oil @ 80*C)
Offline Seanocaoimh
« Reply #3 on: April 13, 2018, 06:42:26 PM »
thanks for the prompt reply lads, would ye think it would be ok to drive if I kept the revs up? why would the revs have a bearing on it and I assume the oil pressure valve is the sensor behind the head, and when removed the pressure  tester would screw in instead. Any idea where I could pick up the appropriate tester
« Reply #4 on: April 13, 2018, 07:54:17 PM »
Correct -- on top of the crankcase, behind the cylinders, under the throttle bodies.
An automotive parts store should either have one or can order one -- an adapter may be nec. (diff. threads/etc)?
Offline Seanocaoimh
« Reply #5 on: April 13, 2018, 08:16:14 PM »
Great stuff! Any ideas about the idle speed illumination of oil light ? Only comes on when engine is warmed up and stopped at traffic lights / slow moving traffic. Should I not ride the bike until I have this problem sorted.
« Reply #6 on: April 13, 2018, 10:11:05 PM »
First, are you sure of the age/condition of the oil, as in, it has definately been changed in line with the service schedule (i.e about 12 months/6k miles). If the oil is old, dirty and worn it will have thinned out which could give low idle oil pressure when hot. If in doubt renew it. :027:
I (personally) would (if happy about oil condition) go straight to eliminating the Oil Pressure Switch for the sake of 25 from Triumph before spending that amount or more on a pressure gauge .... that would be my next step if the new switch didn't clear the 'idle oil light'. :028:
Raising the 'idle speed' definately isn't the answer IMO. :151:
Online Tiggerton
  • Bike: 900 GTPro 2021
« Reply #7 on: April 13, 2018, 11:30:41 PM »
Was the oil filter changed at your last service?
What is your bikes mileage, although oil pumps don't usually give up the ghost on modern triumphs.
I am just thinking that at low revs the oil circulating system may not be efficient.
I do bemoan the fact that oil and temperature gauges are no longer fitted to vehicles these days. They were a great early warning system.
Offline Seanocaoimh
« Reply #8 on: April 14, 2018, 05:00:13 PM »
I have everything stripped back and the low oil pressure sensor wire removed from the sensor. How do I test it to see if it works properly.as I say the oil light comes on at low rpm.
« Reply #9 on: April 14, 2018, 05:41:29 PM »
I would think that the resistance @0 psi should be 10 ohms - that's all you can check with it off really.
 Can you clarify what the condition of the oil and filter is?
