Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Low oil pressure light  (Read 17664 times)
Online Paulhere
Re: Low oil pressure light
« Reply #210 on: March 08, 2019, 08:44:13 AM »
Kinell, to say shoite happens is putting it lightly. Good luck with the rebuild, hope it all goes well.
« Reply #211 on: March 17, 2019, 05:53:00 PM »
*Originally Posted by Roel1964 [+]
When it gives me oil pressure trouble again, then i need to wave the white flag and apply for a divorce (from the bike that is).
For the time being, i will keep on riding the Tiger as long as it purrs and does not grab me by the throat.
Whichever choice, you've given it your all.
May I suggest, tho: the mechanic's bodge (from time immemorial) of stretching - or replacing/shimming - the spring in the oil pressure relief valve to achieve a higher oil pressure.
Mind, there's no free lunch re. the pressure/volume equation (more pressure/less volume, etc) -- but, more pressure may silence that warning light (if it becomes necessary).
"I've a fine felt hat and a strong pair of brogues
and I've rosin in my pocket for my bow.
My fiddle strings are new and I've learned a tune or two
and I'm well prepared to ramble I must go."
Tommy Makem
Offline Roel1964
  • Bike: Tiger 800 (2011)
« Reply #212 on: March 18, 2019, 10:52:59 PM »
That would surely help increasing the pressure at higher RPM when the oil pressure becomes high enough to open the relief valve, so oil is bypassed directly to the sump.
By weakening the spring or shimming the relief valve, you can increase or decrease the maximum oil pressure, which is reached at lets say 5000 to 6000 RPM.
But when the bike is idling, which is about 1200 RPM, the oil pressure relief valve is always closed and shimming or weakening the spring has no influence.
It is at the idle RPM that the bike had a bit too low oil pressure, especially when the engine was hot (in hot weather, or after riding a low speed in hot weather) and the oil light came on.
When the problem is not solved with the new bearings, a last trick i could do, is to increase the idle RPM from 1200 to 1350 or 1400. The RPM is set by the ECU via a stepper motor that moves a mechanical lever, that again offsets the minimum opening of the throttle, so to increase/decrease the idle RPM. By removing the mechanical lever or by disconnecting it from the stepper motor, it is possible to set a fixed idle, simply by adjusting a set screw on the throttle. The engine then will always have the same fixed idle RPM, whether the engine is cold or hot, whether at high altitude or low. Most people that use this trick on the Tiger report that there are no issues when using a fixed idle RPM in any circumstances.
The higher idle RPM will result is a slightly higher oil pressure at idle, just enough to keep the oil light off..... hopefully....
In a few months i know if i need the trick or not.
« Last Edit: March 18, 2019, 10:55:19 PM by Roel1964 »
Offline Roel1964
« Reply #213 on: March 19, 2019, 07:19:09 PM »
I'm referring to the throttle stop screw that can be used to set the idle RPM after disconnecting the stepper motor lever from the stepper motor, so the stepper can not adjust the idle throttle position anymore.
It is quite difficult to adjust this stop screw while the throttle body is installed, so i will try to find a way to do this.
Another way is to keep the lever, move the stepper out of the way (it has to stay connected because otherwise an error will be flagged) and make a construction to adjust the lever using a bolt.
« Last Edit: March 19, 2019, 07:28:16 PM by Roel1964 »
Offline Roel1964
« Reply #214 on: March 23, 2019, 03:55:07 PM »
I decided to attack the problem from 2 sides simultaneous. 1 side is the new bearings and the other side is increasing the idle RPM from 1200 to 1400, because it seems
to be easier than i first thought and it will give some extra oil pressure at idle and me some extra faith and less red-(oil)-light-paranoia.
So today i investigated how the idle stepper motor mechanism and the throttle stop screw at the bottom of the throttle body work.
I discovered that i only need to adjust the throttle stop screw at the bottom of the throttle body to set the minimum idle RPM, which is used when the engine is warmed up.
So i don't need to do move the stepper motor out of the way and i don't need to remove the stepper motor lever at all. The stepper motor mechanism is only able to raise
the RPM above the minimum that is set by the throttle stop screw. The stepper motor can not move the idle RPM below that minimum. So the throttle stop screw is the one
that determines the idle RPM when the engine is warmed up.
The stepper motor increases the idle RPM at a cold start and does this via a lever that moves the throttle valve further open.
When the engine is warmed up, the stepper decreases the RPM again to the minimum idle RPM, which is set by the throttle stop screw.
So to increase the "warm engine" idle RPM, all you have to do is adjusting the throttle stop screw.
Additionally, you can use tuneECU to re-calibrate the ICS (idle control stepper) by re-adjusting the TPS (throttle position sensor) and the screw on top of the stepper motor axis,
so the cold start idle is also higher.
But this re-calibration is not necessary when the cold start idle is high enough and you only want to have a higher idle RPM when the engine is warm.
Original throttle stop screw (M5 thread=0.8 metric) :
New throttle stop screw so you can adjust the idle RPM with the throttle body installed.
The head of the allen bolt (M5x30 or M5 x 25) is pressed into a 3D-printed part that allows to adjust the screw with 1 finger.
The screw is hard to reach, so the shape of the part is designed so you can push against it to rotate the screw in either direction.
This part can also be made out of wood, plexiglas/perspex ... :
New adjustable throttle stop screw assembled :
New throttle stop screw installed at the bottom of the throttle body :
New throttle stop screw can be reached while the throttle body is installed.
I don't have small hands, but i can adjust the screw with 1 finger without touching any hot parts of the engine.
The screw has to be adjusted when the engine is hot, so the stepper motor is not pushing the throttle valve open and the throttle is resting against the throttle stop screw.
Offline Roel1964
« Reply #215 on: May 16, 2019, 10:34:59 PM »
I'm using the bike almost every day now with the new crankshaft bearings and i also increased the idle RPM slightly to 1350 RPM (instead of 1200 RPM) by adjusting
the idle stop screw located at the bottom of the throttle body. (see posts above)
I didn't remove the stepper motor or the lever connected to the stepper motor. This way, the stepper can still increase RPM temporarily when cold starting the bike.
i didn't see the low oil pressure light coming on anymore when the engine is idling after it has been driven hot.
What i learned by fiddling with the idle RPM is that the oil pressure does not decrease linearly with decreasing RPM all the way, but that it drops off fast when RPM is decreased below
about 1100 RPM (at least with my bike). By raising the idle RPM to 1350 RPM, this raises oil pressure enough to stay out of the "low oil pressure zone" even when the engine
is really hot (riding in a traffic jam on a hot day).
So i'm enjoying the smoothness and power of the triple again, without too much worries !
« Reply #216 on: May 17, 2019, 09:33:51 AM »
Nice photos and description.  Well done on the repair.   :028:
