Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: TuneEcu TPS Voltage  (Read 771 times)
Offline steveg
  • Bike: 2012 T800 roadie
TuneEcu TPS Voltage
« on: April 17, 2018, 10:52:12 AM »
Hello
Just hooked up TuneEcu to check for errors and was looking at Sensor voltages
Just wondering what the Throttle values should be ?
Looked in Haynes and no settings
Mine are showing
16.2 & 0.67v
Cheers Steve
Tiger 800 roadie 2012
Offline steveg
Re: TuneEcu TPS Voltage
« Reply #1 on: April 17, 2018, 03:37:40 PM »
From some research looks like my TPS settings are too high as should be 0.60v +-0.02V
Will this have an impact to bike ?
Thanks Steve
Online D6864
  • Bike: White XC
« Reply #2 on: April 17, 2018, 04:11:20 PM »
The target voltage only applies during the calibration process when the Triumph diagnostic tool commands the ECU to close the throttle fully.  It's normal for the voltage to be a bit higher the rest of the time.  I'd leave it alone unless you have a problem.
Offline steveg
« Reply #3 on: April 17, 2018, 04:48:52 PM »
Many thanks
Yep bike is running ok at the moment , so will leave as is
Cheers Steve
