Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Side stand from Low models - will it fit standard?  (Read 3206 times)
Offline Alberto_B
  • Bike: T800XRT
Re: Side stand from Low models - will it fit standard?
« Reply #20 on: May 24, 2018, 11:00:44 PM »
Well, according to Laurence on the TOMCC forum, the parts numbers are:
Laurence said: "I think you also need a different bracket.
T2088062 is the stand leg
T2085900 is the bracket."
Dunno if those numbers correspond or disagree with WoT? The stand leg no. certainly corresponds with what I have and what OHRider said.
Offline Bulldogfour
  • Bike: Tiger 800XRT '17
« Reply #21 on: May 25, 2018, 10:32:50 AM »
 :019:
Ive seen those numbers but Ive gone for the T2081546 leg for post 647xxx VINs.  If it doesnt fit it will go back.  On the schematic that shows this low side stand and the normal one there is only one bracket and one spring.
We will see.  This info is from the UK WoT site.
« Last Edit: May 25, 2018, 10:34:31 AM by Bulldogfour »
Offline Bulldogfour
« Reply #22 on: May 31, 2018, 04:37:45 PM »
*Originally Posted by Bulldogfour [+]
:019:
Now moving to plan B (when I figure out what that is).  T2081546 was nowhere close and is going back.
Offline Bulldogfour
« Reply #23 on: June 10, 2018, 02:25:04 PM »
Well thats me given up on trying to find a way of making my XRT lean a little more on its sidestand.  Ive tried the LOW sidestand and not only does it not give any significant improvement the foot doesnt sit flat - to be expected I guess.  I bought the LOW bracket but when I unpacked it I could see immediately that it wouldnt work as the LOW  doesnt have a centre stand and the centre stand rubber stop on the XRT sits on a plate that is bolted to the sidestand bracket, and with no centre stand the LOW sidestand bracket wont take this.
Just going to have to (a) continue to leave it in gear (b) either put on weight or build up my muscles to use the centre stand more often or (c) improve my selection of parking spots.
« Last Edit: June 10, 2018, 02:26:37 PM by Bulldogfour »
Offline Alberto_B
  • Bike: T800XRT
« Reply #24 on: June 11, 2018, 07:30:35 PM »
Thanks for the info Bulldogfour, saved me another wasted attempt up a blind alley. I think I'll try to have a little milled off the Low foot to try to get the angle flatter (and lower).
I'm also planning on moving the yoke up a bit again, so maybe that will help. If none of that works I think I'll abandon it too.
Offline Bikerboy
  • Bike: 2018 xr800
« Reply #25 on: July 27, 2018, 11:07:15 AM »
Ive seen suggestions elsewhere that fitting a washer behind the bracket on the bottom bolt changes the angle of sidestand and solves the problem
Offline Alberto_B
  • Bike: T800XRT
« Reply #26 on: August 20, 2018, 03:52:19 PM »
Hi, sorry I only just saw this - thanks for that suggestion I'll investigate.
