Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Screen Adjustment  (Read 517 times)
Offline Robin Catbush
Screen Adjustment
« on: April 29, 2018, 12:12:36 PM »
Made myself a slotted bracket this morning, it allows a small amount of forward movement on the screen for more wind deflection, see picture,works a treat too, yea go me... :490:
Re: Screen Adjustment
« Reply #1 on: April 29, 2018, 12:28:08 PM »
Looks good
Is it not putting pressure on the two front fixings?
« Reply #2 on: April 29, 2018, 01:07:00 PM »
Not really, I took the screen off, removed the 'A' bracket and spaced the two fixing bolts out around six mill so the point at the bottom of the screen didn't catch, the tube part at the front fixing swivels already, it's only the point of the screen that stops it moving more, hence the spacing. This can be fitted to a standard screen to save buying a new one, tight but that I am... :001:
