Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: andreani  (Read 2713 times)
Offline Old Guy
andreani
« on: May 04, 2018, 04:59:10 PM »
Hi Has anybody with Andreani cartridges had problems with little or no damping effect from the adjusters. Regards Bob
Offline Gasman
Re: andreani
« Reply #1 on: May 04, 2018, 08:45:12 PM »
Mine seem to work ok. When I thought I had a problem it turned out to be the rear shock not throwing enough weight on the front to allow it to work correctly. Rear shock adjusted problem solved. Sometimes professional help is required.
Offline davamb
  • Today will be difficult, but tomorrow- good riding
  • Bike: 800 XRx
Re: andreani
« Reply #2 on: May 05, 2018, 03:05:07 AM »
Hi OldG,
are you sure the correct position of the damper rod was set at install as per the instructions?
Cheers,
Dave
Offline Old Guy
Re: andreani
« Reply #3 on: May 05, 2018, 06:44:23 AM »
Hi Guy thanks for the replies, yes I did the 4 turns in on install, maybe Gasman is right and I need pro assistance as there is very little difference between in and out.
Offline davamb
  • Bike: 800 XRx
Re: andreani
« Reply #4 on: May 05, 2018, 12:58:01 PM »
Sorry Bob, just re-reading your original post, I'm not exactly sure what you're asking; are you saying that turning the adjusters makes no change in the amount of damping, or that there is little damping to begin with? Also, which sides - the compression ("C") fork or the rebound ("R") fork or both?
Cheers,
Dave
Offline Old Guy
Re: andreani
« Reply #5 on: May 05, 2018, 02:58:29 PM »
HI Davamb, There seems to a slight change on the rebound from fully in to fully out but on the comp side none as far as I can tell, its as if the needles valves are not closing down enough. Bob
Offline kolalysy
  • Bike: Tiger 800 xrx
Re: andreani
« Reply #6 on: August 30, 2018, 03:04:57 PM »
Smoething is wrong, there is a significant difference when you turn the knob.
Konrad Tiger xrx
Offline Boz
  • Bike: Tiger XRX
Re: andreani
« Reply #7 on: September 11, 2018, 09:18:21 PM »
Hi, I have Andreani front forks fitted.  Did you have them set up by a specialist? I see you are Bristol based. JHS Racing in Keynsham May be worth a visit. They have a couple of suspension specialists who should able to help. I believe they do a lot of suspension upgrades.
Offline Old Guy
Re: andreani
« Reply #8 on: September 16, 2018, 05:09:44 PM »
Hi Bob thanks for you reply, have you used them before.
                       Regards Bob
Offline Boz
  • Bike: Tiger XRX
Re: andreani
« Reply #9 on: September 16, 2018, 05:59:13 PM »
Yes, twice.  Once for MOT which involved them having to complete non scheduled work on a rear brake calliper which failed the initial test. Second time was for replacement left and right lower fork stanchions, new fork internals, replacement front pads as they become contaminated with fork oil from leaking seal and lastly replacement of top yoke as the original was seized to the forks due to corroded bolt, as well as  setting up the front suspension.Labour rate was 50 per hour.  Work appears to be of good quality. Time will tell. They kept me well informed on costs and timings. As I mentioned in an earlier post, they seem do a lot of suspension work, notably for racing.
