Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Rear rebound adjustment nut  (Read 1054 times)
Offline Gebrauchtwagen83
  • Bike: Tiger 800xcx
Re: Rear rebound adjustment nut
« Reply #10 on: May 05, 2018, 09:22:13 AM »
Just the legal 3 month one which will be in house. The problem is the guy was a misery and nit picking over everything so I doubt they will want to stick a new shock on. Got a bit of a battle on my hands I think
  • Bike: XC,XCX, CB1300,
« Reply #11 on: May 05, 2018, 12:09:21 PM »
Maybe save the mental aggravation and treat yourself to an after-market shock, or see if someone can repair it. I'v never taken one apart myself so I'm not sure what's involved but that might be worth a try too.
« Reply #12 on: May 05, 2018, 12:11:34 PM »
Ive got some trips and a house move coming up so Ill probably just have to settle for a fix at the moment but certainly will look at that later in the year.  Cheers
« Reply #13 on: May 05, 2018, 12:19:42 PM »
*Originally Posted by Gebrauchtwagen83 [+]
There is no give even when I jump up and down on it.
This problem... 'no give'...  sounds odd too. You should still get travel with the spring. The rebound screw only affects the rate-of-travel, not the distance up and down. Pre-load might be wound full-on.
