Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Ignored downshifts ...  (Read 1950 times)
Offline Davy
  • Bike: 2018 silver xrt
« on: May 07, 2018, 12:28:23 PM »
I've had my 2012 roadie for 2 years now, and shifting gears has always been faultless. Last weekend i did a 500km daytrip, and in the last 200km's i noticed that sometimes my downshifts were being ignored. In order to get it down a gear, i had to make the shifting movement slow and deliberate. I had it a couple of times, but today the problem seems gone (the daytrip was quite a spirited ride)
Is this a signal of worse to come?
« Last Edit: May 07, 2018, 12:30:08 PM by Davy »
Re: Ignored downshifts ...
« Reply #1 on: May 07, 2018, 12:41:29 PM »
You probably need to take the clutch cover off and look at that end of the selector shaft.
There are two possible problems you could find, a broken return spring or the selector pin has parted company with the selector
  • Bike: XC,XCX, CB1300,
« Reply #2 on: May 07, 2018, 01:09:58 PM »
Make sure your oil level is right and not too close to replacement date.
Check clutch cable  freeplay.
Offline Maxrock
  • Bike: Tiger 800 ABS
« Reply #3 on: May 16, 2018, 11:38:46 AM »
Noticed mine started doing this yesterday, oil level all good. Only got the bike in January so maybe I'll take it back into the dealer to have a look, its a 2013 roadie.
Offline Davy
« Reply #4 on: June 11, 2018, 05:50:05 PM »
*Originally Posted by Maxrock [+]
Im calling my dealer about this tomorrow (i can change an oil filter but ill leave this to the more skilled mechanics :) ) Any news on your part?
Offline Maxrock
« Reply #5 on: June 15, 2018, 02:31:54 PM »
Mine seems to have stopped doing this but its probably down to me changing the way I down shift after reading another post about this issue, it only seems to do it when I come to a complete stop still in a higher gear, if I drop down through the box as I decelerate there is no problem....I guess it was down to me being lazy with the gears and trying to block shift.
« Reply #6 on: June 15, 2018, 03:39:17 PM »
That's a fairly normal characteristic with a motorcycle gearbox
Offline Turbo100
  • Bike: 17 Tiger 800 XRt
« Reply #7 on: June 15, 2018, 04:49:41 PM »
Mine has done this from day one and it seems its perfectly normal. I only notice it when for some reason I haven't downshifted through the box before I come to a standstill and its still in a higher gear.
Offline Davy
« Reply #8 on: June 15, 2018, 04:58:06 PM »
*Originally Posted by Turbo100 [+]
Yes, what you describe is normal (on any motorycle), but that is not what we are talking about here. This is while driving ...
Anyway, when i explained it to the dealer he immediately suspected what the issue was, and i think he referred to the same part Rtwo was talking about. The next day he confirmed it was the case, part is ordered. Shouldnt be that expensive to fix ...
« Reply #9 on: June 15, 2018, 05:07:06 PM »
I guess that it depends on what you call expensive
There was someone here charged 450 to replace the shaft
