Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: White connector under the seat  (Read 6953 times)
Offline Number14
  • Bike: Tiger
Re: White connector under the seat
« Reply #20 on: June 24, 2018, 10:07:31 PM »
Ummm, I don't quite understand this.
I've just opened up both parts of the white connector, and the wired up connector is MALE.
Therefore, all I need to buy is some FEMALE pins and wire seals.
The seals and female pins just need to be connected to the sat nav wires, and pushed into the existing connector (the one with the six black blanking plugs).
Or am I missing something?
The white plug that is connected to the bike electrical harness is female and the bit with the blanks in is male - it fits inside the femal bit.
If you look at the pins inside the female connector they are male.  The female pins go inside the male connector.  If you are going to use the existing connectors then you just need a couple of female pins and seals.
I chose to buy a new male connector as I want to keep the original one to refit in case I sell the bike.
Offline bucksfizz
  • Bike: 18 Tiger 800 XRT
« Reply #21 on: June 24, 2018, 10:58:52 PM »
*Originally Posted by Number14 [+]
OK, now I get it - the female plug houses the male pins.
I have a mind to buy some female pins, and insert those into the housing.
I do understand your need to replace the plug if you decide to sell, though.
BTW, where did you buy your Sumitomo connector from?
Offline infoinfo
« Reply #22 on: June 26, 2018, 10:58:35 AM »
Its intended use is for a future accessory. Battery, Ignition, Ground, CAN+, CAN-
« Reply #23 on: June 26, 2018, 02:05:38 PM »
https://www.easternbeaver.com/Main/Elec__Products/Connectors/connectors.html
Offline T800XC
« Reply #24 on: June 26, 2018, 06:28:44 PM »
*Originally Posted by infoinfo [+]
Hmmmm....interesting, and potentially useful.  :028:
Offline Number14
  • Bike: Tiger
« Reply #25 on: June 26, 2018, 08:49:18 PM »
http://www.automotiveconnectors.com/connector-terminals.html
Offline bucksfizz
« Reply #26 on: June 26, 2018, 10:55:05 PM »
Offline pme
  • Bike: xrx lrh 2018
« Reply #27 on: July 01, 2018, 10:44:23 AM »
If anyone succeeds in getting the right pin part could they post the part number, this could be a very useful mod
thanks
chris
Offline pme
« Reply #28 on: July 01, 2018, 11:06:03 AM »
I've just taken a punt on the parts, i'll post details when i have tried them out, hopefully this week.
Offline bucksfizz
« Reply #29 on: July 01, 2018, 12:07:44 PM »
*Originally Posted by pme [+]
thanks
chris
I ended up buying these connectors from eBay - item number 282103009944.
The holes in the seals were far too large (blue), but fortunately I had some smaller seals (green).
If you need the smaller seals, then it may be worth contacting the seller.
They crimped on easily, and fit directly into the socket supplied on the bike:
My sat nav (TomTom Rider 450) now switches on with the ignition.
