Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Removed and refitted rear wheel, ABS, TC and IML lights now on?  (Read 2295 times)
Offline HH007
  • Bike: Blue XRx+beak
Hi Everyone,
Well, thought I was being smart and saving a few quid buy taking my rear wheel to a tyre fitter, getting a new tyre and then refitting the wheel myself. Appears I might have done something wrong!
The ABS light now wont stop flashing and a few hundred meters down the road the ABS, TC and IML lights are all permanently on.
Not sure what's happened as I don't think I touched the ABS sensor and have refitted the wheel as per muddysump's instructions, albeit the chain adjuster blocks appear to be the same width top and bottom now as opposed to his bike.
Any help much appreciated.
John
 :440:
Online Rtwo
Re: Removed and refitted rear wheel, ABS, TC and IML lights now on?
« Reply #1 on: May 12, 2018, 12:36:25 PM »
It may well clear after 3 heat cycles or you can plug a PC into it and clear the DTCs
Offline RoadWarrior
  • Ex Member
« Reply #2 on: May 12, 2018, 12:58:49 PM »
did you remove the ABS sensor before taking the wheel out?
Offline HH007
« Reply #3 on: May 12, 2018, 02:15:12 PM »
*Originally Posted by RoadWarrior [+]
No, should I have?  :005:
Offline HH007
« Reply #4 on: May 12, 2018, 02:18:40 PM »
Thanks, heat cycles?
Online Rtwo
« Reply #5 on: May 12, 2018, 02:23:31 PM »
*Originally Posted by HH007 [+]
Running it from cold to hot
Or just 3 rides really
If the system doesn't see the problem for 3 heat cycles, it just resets the error indication
Offline HH007
« Reply #6 on: May 12, 2018, 03:16:50 PM »
OK, thanks, I'll give that a go. Any idea what could have caused the error?
Offline RoadWarrior
  • Ex Member
« Reply #7 on: May 12, 2018, 04:05:38 PM »
Not necessarily but I do so as to prevent any chance of damaging it when removing or refitting the wheel.
I would suggest that pulling it for a quick inspection to ensure the tip hasn't been knocked off or damaged would be the quickest way to rule out the most likey cause of the issue.
Offline HH007
« Reply #8 on: May 12, 2018, 04:45:05 PM »
Thanks. That sounds like a good idea, I'll look for damage. So, it's supposed to have a removable tip?
Offline RoadWarrior
  • Ex Member
« Reply #9 on: May 12, 2018, 04:50:19 PM »
The tip itself isn't removable, but it protrudes through the hole to be very close to the ring of slots on the disc.  it makes it very vulnerable especially when refitting the wheel, same applies for the front wheel.
