Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Removed and refitted rear wheel, ABS, TC and IML lights now on?  (Read 2294 times)
Offline fasted
  • Bike: 2016 XRT
Re: Removed and refitted rear wheel, ABS, TC and IML lights now on?
« Reply #10 on: May 12, 2018, 08:56:43 PM »
Muddysump video is not an ABS brake bike , when I did my tires I removed the sensor no problema
Offline HH007
  • Bike: Blue XRx+beak
« Reply #11 on: May 13, 2018, 03:45:53 PM »
I removed the ABS sensor and no obvious sign of damage. Looks like it lines up OK with the ring. Does this look OK? I've nothing to compare it against!
Online T800XC
« Reply #12 on: May 13, 2018, 04:21:23 PM »
Did you check the error DTCs? That would at least let you know the cause of the ABS light coming on.
As you've got an XRX you should be able to check for DTCs by holding the 'up' and 'info' buttons pressed while turning on the ignition. The codes should be displayed on the dash.
Offline Captain Crazy
  • Bike: Tiger 800 XC-R
« Reply #13 on: May 13, 2018, 04:23:25 PM »
On the surface (so to speak) ... looks OK from here  :027:  Hard to tell TBH.
Have you hooked up your bike to a laptop and checked for ant error codes ....?  Would be the best way to check what's up, then check any codes against the WSM etc ...
Did you check & set the Air Gap when you refitted your wheel as per the handbook and/or WSM?
CC
TIGER 800XCR - ''BLACK on BLACK''
Offline HH007
« Reply #14 on: May 13, 2018, 04:46:48 PM »
Thanks very much, I'll do that and report back.
Offline HH007
« Reply #15 on: May 13, 2018, 04:48:34 PM »
*Originally Posted by Captain Crazy [+]
CC
That's really helpful, thanks. Didn't realise that was a requirement. I've spun the back wheel and there appears to be a tiny distortion in the ABS ring, perhaps ever so slightly bent, hard to tell, might be, maybe not. I'll check the error codes.
« Last Edit: May 13, 2018, 05:39:41 PM by HH007 »
« Reply #16 on: May 13, 2018, 05:39:56 PM »
Hopefully the ABS Pulsar Ring is not Bent/Damaged as a new one will set you back over 190 on it's own! And yes they are easily 'knocked/damaged' by half-arsed handling etc ...  :138:
Best of luck with the Code checking. Let us know how it goes.
CC
Offline HH007
« Reply #17 on: May 13, 2018, 05:47:52 PM »
CC
Thanks and YIKES!
Fault codes PO500 and P1521
(Got those by holding/info and turning ignition on)
Found the codes..
P1521 Lost communication with ABS
P0500 Vehicle speed sensor malfunction
Not sure this helps!
Maybe I need to take the bike for a run for it to show any ABS Diagnostic Trouble Codes?
« Last Edit: May 13, 2018, 05:59:53 PM by HH007 »
« Reply #18 on: May 13, 2018, 05:53:39 PM »
*Originally Posted by HH007 [+]
Trying to find those codes but can't see them listed.
Try here:
https://www.tiger800.co.uk/index.php/topic,14967.0.html
Offline HH007
« Reply #19 on: May 13, 2018, 05:56:24 PM »
Thanks and updated my post. Much appreciated!
