Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Removed and refitted rear wheel, ABS, TC and IML lights now on?  (Read 2293 times)
Offline Captain Crazy
  • Bike: Tiger 800 XC-R
Re: Removed and refitted rear wheel, ABS, TC and IML lights now on?
« Reply #20 on: May 13, 2018, 06:19:03 PM »
P0500 Error Code refers back to C1613 and can be checked by following this advise from the WSM ....
Good luck ...  :028:
CC
TIGER 800XCR - ''BLACK on BLACK''
« Reply #21 on: May 13, 2018, 06:26:39 PM »
Hi H
Sorry, just back from Gloucester Megameet and fell asleep in front of the laptop, got called to eat and quickly put the link for the code list but should have recognised those codes straight away considering I've just been there.  :005:
Maybe have a read through these for background info/help:
https://www.tiger800.co.uk/index.php/topic,24031.0.html
https://www.tiger800.co.uk/index.php/topic,22590.10.html
Offline HH007
  • Bike: Blue XRx+beak
« Reply #22 on: May 13, 2018, 08:37:08 PM »
Hi H
Thanks Stevie, I'll have a read. I've been told that as the speedo is working fine, the lights should clear after a few runs. I'll try that first!
« Reply #23 on: May 13, 2018, 08:56:15 PM »
*Originally Posted by HH007 [+]
... the speedo is working fine, ...
That's a major difference, I lost the speedo as well, so probably slim chance it would be anything like my issue which actually linked to another issue at the same time, pulsing headlights which was a knackered rectifier/regulator.
Offline HH007
« Reply #24 on: May 25, 2018, 09:40:16 PM »
Had the rear wheel, calliper bracket and ABS sensor out and refitted and problem solved. Likely it was the ABS sensor wasn't lined up correctly, perhaps knocked it when I was putting the wheel in.
A couple of rides later the ABS, TC and IML lights have all gone out!
Thanks everyone, thought I'd post this in case anyone else has the same problem.
 :417:
