Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Brake Pin Woes  (Read 8267 times)
Offline biscut1975
Brake Pin Woes
« on: May 14, 2018, 08:50:54 PM »
Think I know the answer to this already but hoped someone might have a tip or trick to help...
Finally got round to removing the covers for the front brake pins so I can replace the pads (and discs) and found:
Is there a trick to getting this rounded 5mm allen bolt out or is the only hope to drill the bugger? I do have a set of easy outs (no idea how to use them mind) but never used them. Any help would be really appreciated please :-)
Thank you very much for any advice anyone can give
DavidT
Offline taff
  • Bike: Tiger XC
Re: Brake Pin Woes
« Reply #1 on: May 14, 2018, 08:55:27 PM »
The usual first thing I try on a rounded Hex is a Torx bit
Offline biscut1975
Re: Brake Pin Woes
« Reply #2 on: May 14, 2018, 08:57:23 PM »
awesome idea, will give that a try, thank you very much for the quick reply :-)
Offline RoadWarrior
  • Ex Member
Re: Brake Pin Woes
« Reply #3 on: May 14, 2018, 11:09:36 PM »
I had to hammer a spline drive socket in, That's not a torx BTW but similar. I then bought a Stainless replacement
https://www.ebay.co.uk/itm/S-Steel-Nissin-Caliper-Pad-Pin-M10-x-1-0mm-pitch-60mm-overall-length-5-8mm-S-/302401455728
Offline biscut1975
Re: Brake Pin Woes
« Reply #4 on: May 15, 2018, 09:15:09 AM »
*Originally Posted by RoadWarrior [+]
Thank you very much for the link, was just looking at World of Triumph and they want 9 each for them so many thanks for that :-) Will have a look in to the spline drive socket later this morning. Don't really want to drill it out unless I have no other options
Offline ccmp
  • Bike: 2015 800 xca
Re: Brake Pin Woes
« Reply #5 on: May 15, 2018, 09:28:04 AM »
Does that pin fit front and back?
Re: Brake Pin Woes
« Reply #6 on: May 15, 2018, 10:00:49 AM »
Who was it that produced stainless pins with a 7 or 8mm head?  Mine must be 6 years old and are perfect.  Triumphs own pins are almost an annual replacement.
Offline biscut1975
Re: Brake Pin Woes
« Reply #7 on: May 15, 2018, 11:40:33 AM »
have ordered two pins so will replace both of them once I replace the pads, still debating which pads and discs to go for at the moment ;-)
Re: Brake Pin Woes
« Reply #8 on: May 15, 2018, 11:43:47 AM »
EBC HH or equivalent for the pads
I replaced front discs recently with new discs from All Bike Engineering
http://www.allbikeengineering.co.uk/
They might not be in their catalogue yet but they do them.
Offline Captain Crazy
  • Bike: Tiger 800 XC-R
Re: Brake Pin Woes
« Reply #9 on: May 15, 2018, 11:56:57 AM »
That would be .....  paulvfr
He was on Fleabay  for a while https://feedback.ebay.co.uk/ws/eBayISAPI.dll?ViewFeedback2&userid=paulvfr&ftab=AllFeedback but seems to have vanished? And not been on here either for some time!  :027:
And yer ... his pins are pretty puka ... still.  :001:    :028:
CC
TIGER 800XCR - ''BLACK on BLACK''
