Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Brake Pin Woes  (Read 5813 times)
Online Turbo100
  • Bike: 17 Tiger 800 XRt
Re: Brake Pin Woes
« Reply #20 on: May 15, 2018, 09:00:21 PM »
*Originally Posted by taff [+]
That's exactly what they are, a secondary locking (i.e. safety) device there to stop the pins falling out if they loose their torque. Losing your pads at speed really is not something you want to do. I absolutely would not fit the pins that are photographed above that does not have the secondary locking, christ, I wouldn't even fit pads to my mountain bike without the little locking clip on the end of the pin.
These are what I recently fitted:
3 Stainless pins 11.85 (3.95 each) beautiful quality free P&P
https://www.ebay.co.uk/itm/S-Steel-Nissin-Caliper-Pad-Pin-M10-x-1-0mm-pitch-60mm-overall-length-5-8mm-S/302401455728?hash=item4668880670
3 Stainless caps 7.50 (2.50 each) free P&P
https://www.ebay.co.uk/itm/NISSIN-STAINLESS-STEEL-CALIPER-BRAKE-PAD-PIN-SCREW-CAP-BRITISH-Made/253533478892?hash=item3b07c5dfec:g:2t8AAOSwC81awLv1
Offline taff
  • Bike: Tiger XC
Re: Brake Pin Woes
« Reply #21 on: May 15, 2018, 09:12:09 PM »
exacly the same ones that I fitted to mine   :028:
Offline dazza76
Re: Brake Pin Woes
« Reply #22 on: May 16, 2018, 11:27:43 AM »
Just ordered the same pins for mine to save any future drama's.
Hopefully the OP can remove their bolt with by hammering in a suitable sized torx, usually a good result for rounded off allen key bolts.
Online Turbo100
Re: Brake Pin Woes
« Reply #23 on: May 16, 2018, 11:58:42 AM »
*Originally Posted by dazza76 [+]
I think you will be well impressed with the pins, real top quantity and worth every penny.
Offline biscut1975
Re: Brake Pin Woes
« Reply #24 on: May 16, 2018, 08:14:56 PM »
Ordered pins and caps so waiting for them to come through. Also ordered a spline drive socket set so hopefully this weekend i should be able to get the bugger out :)
thank you very much for all the advice everyone has posted, will let you know how much swearing....errr...i mean time it takes to get the thing out
Offline biscut1975
Re: Brake Pin Woes
« Reply #25 on: May 23, 2018, 09:16:27 PM »
Ok, just to close the thread...even with hammering in the spline drive socket the bugger didnt move, took it to RAD in Northampton and he did the same as me but was braver in using a blow torch to heat up the caliper for a few seconds...got the blasted thing out finally and put the new pin in for me
Have to say I wouldnt have been brave enough to use a blow torch on the caliper so glad he did it !! :-) Just need to wait for the new pads and discs to come through and I can do it all again ;-)
Online Rtwo
Re: Brake Pin Woes
« Reply #26 on: May 24, 2018, 06:15:32 AM »
I'd want to change the piston seals after using a blow torch on the caliper.
They could well be just fine but if you have it to bits, you may as well do the seals
Offline Gasman
Re: Brake Pin Woes
« Reply #27 on: May 24, 2018, 09:04:35 AM »
If anyone is interested I have a full set of calipers fully working with removable pins for sale. I have just changed mine for black ones so have a spare set. Will put them in the for sale section when I get round to it.
Offline ccmp
  • Bike: 2015 800 xca
Re: Brake Pin Woes
« Reply #28 on: May 24, 2018, 10:35:42 AM »
On reading this thread. I ordered these last week. Delivered and fitted. Thanks to the forum.
Offline biscut1975
Re: Brake Pin Woes
« Reply #29 on: May 24, 2018, 11:42:05 AM »
Hi RTwo, will have a look at them when I get the discs and pads through, as you say if its all in bits might as well replace them too. Thanks for the thought.
