Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Where does this fit  (Read 913 times)
Offline Gasman
Where does this fit
« on: May 16, 2018, 09:17:04 PM »
I have seen a clutch cable guide offered for sale all over the place. Where the hell does it go. I have trawled the internet but cant find an answer.
  • Bike: 2016 Tiger XRt
Re: Where does this fit
« Reply #1 on: May 16, 2018, 09:34:38 PM »
Pretty sure that will be the bracket the bottom end of the clutch cable outer is adjusted and locked in .... top of the cam chain cover / bottom of the cylinders RH side.
Offline Gasman
« Reply #2 on: May 16, 2018, 09:38:11 PM »
Thanks for that, just looked and cant really see how it fits. In the pictures it appears to have 2 fixing holes but I can only see one on the bike.
Offline Gasman
« Reply #3 on: May 16, 2018, 10:07:52 PM »
Just had another look and have sorted it out thanks.
« Reply #4 on: May 17, 2018, 08:46:30 AM »
Did you locate where the bracket fits as I have just taken a look at the bike and as you mentioned the standard bracket (on my 2016) only has 1 fixing screw hole and a small locating hole that sits on a locating dowel. Can't find any other clutch cable related brackets.  :187:
« Reply #5 on: May 17, 2018, 08:57:55 AM »
*Originally Posted by Gasman [+]
Thanks for that, just looked and can’t really see how it fits. In the pictures it appears to have 2 fixing holes but I can only see one on the bike.
Just looked at the bracket again and enlarged the picture and although it looks like 2 fixing holes initially I'm fairly sure the upper hole is smaller and is the dowel locating hole.  :028:
« Last Edit: May 17, 2018, 09:53:24 AM by Stevie.P »
Offline FredCraner
  • Bike: Tiger 800 roadie
« Reply #6 on: May 17, 2018, 10:53:59 AM »
I was tempted by the WOT offer, but then had a moment of clarity and realised that because I had to actually research where it went I didn't need it!  The original RRP is crazy for a tiny piece of metal, plus the rest of the engine is black as they only do grey and red.
I'm saving my money for when the Arrow cans are reduced again!
« Reply #7 on: May 17, 2018, 03:23:13 PM »
*Originally Posted by FredCraner [+]
I was tempted by the WOT offer, but then had a moment of clarity ...
I did the same, had the red bracket and oil filler cap in the basket then decided that really the current black bits do the job quite adequately. Also removed the Optimate/power socket lead as I really have enough adaptors. Bought a few cheap bargains though.  :028:
Offline Gasman
« Reply #8 on: May 17, 2018, 04:32:06 PM »
I got the grey one. You cant beat a bit of cheap bling.
