Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Bike stalls when pressure is put on gear lever  (Read 3107 times)
Offline Treemonkey
« on: May 24, 2018, 03:12:25 PM »
Hi. Wanting to pick the brains of people here. Ive got a 800 roadie from 2011, and I broke down in Spain. It turned out to be the regulator and we also discovered a burnt stator coil. These were replaced along with the starter solenoid and battery. The charging system now works ok but on trying to select a gear ( and I mean just moving the lever, not actually putting in gear) the bike stalls. I have checked the gear position sensor ( tried swapping with a new one) by passed the clutch, and sidestand sensor. Im thinking now the high voltage has buggered the ecu. Anyone any thoughts?
Re: Bike stalls when pressure is put on gear lever
« Reply #1 on: May 24, 2018, 04:04:28 PM »
If the bike runs then the ecu is unlikely to be a problem.
Could be the biting point of the clutch has changed to the extent you're not actually engaging it at all.  Does the bike jerk forward or just die?
Offline Treemonkey
« Reply #2 on: May 24, 2018, 05:27:06 PM »
I dont think its the clutch. Even a small amount of pressure cuts the engine. Also when riding doing fearless changes the Bike effectively cuts out and bump starts. The only reason Im thinking ecu is because the sensors that would cut the bikes engine for eg the sidestand switch have all been checked and bypassed leaving me to think there must be something wrong with the ecu not knowing that one of the sensors is functioning. This I would have thought could be possible due to high voltages being put around the wiring when the stator and regulator failed.
Offline Treemonkey
« Reply #3 on: May 24, 2018, 05:28:13 PM »
* gearless not fearless 🤪
« Reply #4 on: May 24, 2018, 05:42:52 PM »
I've heard of a similar issue due to a weak spring on the side stand causing it to trip the switch but if you have it by-passed ??
TPS maybe, long shot but possible
  • Bike: 2016 Tiger XRt
« Reply #5 on: May 24, 2018, 05:55:05 PM »
*Originally Posted by Treemonkey [+]
... leaving me to think there must be something wrong with the ecu not knowing that one of the sensors is functioning. This I would have thought could be possible due to high voltages being put around the wiring when the stator and regulator failed.
... in which case my no.1 suggestion would be (if you haven't got one) get an OBD cable/interface and download Tigertool and check the ECU for fault codes.  :084:
Offline Treemonkey
« Reply #6 on: May 24, 2018, 06:06:49 PM »
Cheers for the replies. No fault codes coming up. Im still waiting for the Bike to be sent back from Spain but checked this before I left. Basically wanting to give myself a list to check when it comes back.
Ill check the TPS and I was thinking maybe the crank position sensor too? Although the garage said theyd checked all this Ill go over everything again. The only ones Im definite about are the clutch, gear selector and sidestand sensors because I was there when they did these
« Reply #7 on: May 24, 2018, 06:07:58 PM »
Surely the MIL  would light?
Offline Treemonkey
« Reply #8 on: May 24, 2018, 06:11:39 PM »
MIL?
Offline Treemonkey
« Reply #9 on: May 24, 2018, 06:17:30 PM »
Ah the engine light? This was cancelled from the regulator fault and now no codes coming up.
