Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Front Master Cylinder Banjo Bolt  (Read 947 times)
Offline Bladerunner99
  • Bike: 2018 XCA
« on: June 03, 2018, 10:46:41 AM »
Could anyone please advise me of the front master cylinder banjo bolt 'head' size?
I have loosened the bolt to reposition the front brake line in order to fit barkbusters to my 2018 XCA.  Problem is the bolts appear to be a loose fit 14mm head size but have rounded points unlike conventional bolt heads, upshot is 12 point socket does not grip, so I am considering the purchase of a 6 point wall drive socket but want to make sure of correct size.  Any advice is greatly appreciated.
Ride to work. Work to ride
Offline Turbo100
  • Bike: 17 Tiger 800 XRt
Re: Front Master Cylinder Banjo Bolt
« Reply #1 on: June 03, 2018, 02:20:04 PM »
Its a 14mm, get a 6 sided like you say.
Offline Gasman
« Reply #2 on: June 03, 2018, 08:39:47 PM »
Yes 14mm just replaced all of mine with a standard 14mm spanner.
Offline chico
« Reply #3 on: June 04, 2018, 04:10:41 AM »
Get a new banjo bolt, they're cheap.
« Reply #4 on: June 04, 2018, 06:27:55 AM »
Offline Rodders
« Reply #5 on: June 04, 2018, 07:20:36 AM »
I think that you will find that hydraulic banjos are still imperial sized - I had this problem last year on my Explorer - try a 9/16.
BSA Bantam D1, Ducati 250 Mach III, Honda CB250G, BMW R90S, Honda CB400T, Honda CB550K, BMW R1100R, Triumph Tiger 800, Triumph Tiger Explorer, Triumph Tiger 800 XRT
  • Bike: 2018 XCA
« Reply #6 on: June 04, 2018, 11:37:16 AM »
Now sorted, used a 14mm 6 point socket.
Many thanks for all the replies.
