Home
Search
Member Map
Photos Gallery
Login
Register
VIEW MEMBERS
ERROR LOG
MAINTAIN DATABASE
ATTACH & AVATARS
MANAGE THEMES
BLOCK LIST
Login/Register
RECENT POSTS
UNREAD TOPICS
UNREAD REPLIES
BOOK MARKS
PHOTOS GALLERY
HELP PAGES
ACCOUNT
SETTINGS
FORUM
PROFILE
MY POSTS
MESSAGES
NEW = 0
LOGOUT
Recent Posts
Please
login
or
register
LOGIN
JOIN
Triumph Tiger 800 Forum
Problem starting when hot..... Is the starter motor the problem?
17 Aug 22, 00:10 am
1
2
3
4
Go Down
Author
Problem starting when hot..... Is the starter motor the problem? (Read 13010 times)
Paulhere
Tiger Jedi ‐
2292
#30
Paulhere
Tiger Jedi
Bike/Model: Tiger 800 XRx
Country:
Re: Problem starting when hot..... Is the starter motor the problem?
Reply #30 on:
Jun 22, 2022, 05.13 pm
Maybe poor connections.
duggers
Tiger Cub ‐
10
#31
duggers
Tiger Cub
Reply #31 on:
Jun 22, 2022, 05.23 pm
That's possible. I just arrived home after a decent 45 minute run on a hot day, ready to do some testing, and it started not once but 3 times. Battery tester shows battery and charging circuit good. Started no problem when cold earlier too. Wonder if there may be a corroded earth somewhere, because there are no loose connections elsewhere.
The only other thing I can think of is that the starter had only been used once prior to today's trip, maybe the brushes were so new they hadn't bedded to the commutator properly. To be sure I'm going to have to rise it for a while, see if it happens again, if not then it was the above and if it does I'll investigate the earth/ground wiring.
Paulhere
Tiger Jedi ‐
2292
#32
Paulhere
Tiger Jedi
Country:
Reply #32 on:
Jun 22, 2022, 05.55 pm
Tell us about your starter if it's a good'n, what make, 'ow much & where from eh?
duggers
Tiger Cub ‐
10
#33
duggers
Tiger Cub
Reply #33 on:
Jun 22, 2022, 07.20 pm
Hi Paul,
Yes I'll do that if I can get to the bottom of what happened today. Hopefully it was just the brushes on the starter being brand new and not contacting the armature fully. Over the next few weeks I'll be riding quite a bit so it will get tested.
Rgds
Ian
Paulhere
Tiger Jedi ‐
2292
#34
Paulhere
Tiger Jedi
Country:
Reply #34 on:
Jun 22, 2022, 07.29 pm
Good luck with it.
duggers
Tiger Cub ‐
10
#35
duggers
Tiger Cub
Reply #35 on:
Jul 01, 2022, 01.11 pm
Hi Paul,
An update. I made the same journey this week as last week and I had the same hot start problem. I returned home and again no hot start problem. I think I'll avoid that problematic location and my problem is solved!
Seriously though, it points to a certain riding pattern being problematic. Today I cleaned up the earth tags, and will run again for a while. If problem recurs, I'll take a closer look at the starter relay, though after that I may be forced to confront the fact that the starter I used is not up to the job. The hot start issue is either there or it's not, meaning that there's no point where the starting is weak but will still start the bike. It is digital in nature, which still leads me to think that the issue is not starter related, and is more likely the relay or some other electrical issue (but there's not much to this circuit really)
Regards
Ian
duggers
Tiger Cub ‐
10
#36
duggers
Tiger Cub
Reply #36 on:
Jul 14, 2022, 09.46 am
OK, hot start issue well and truly fixed, and the cause was......
A knackered battery, at only 5 months old.
I fitted a lithium hybrid battery and it's starting like a good un even in this extra hot weather.
I found the root cause by taking my battery booster and battery tester out with me and riding the bike for 30 minutes or so. Then stopped somewhere safe, confirmed that it wouldn't start, then clipped on the booster. Bike started. Then I stopped the bike and unclipped the booster and clipped on the tester. Battery charge level showed optimum confirming that the voltage was OK. Then I started the bike again and confirmed that the charging was OK. All other causes eliminated, so I bought a replacement battery and the hot start issue is gone.
Ian
chico
Tiger Jedi ‐
1463
#37
chico
Tiger Jedi
Bike/Model: 2017 XRX
Country:
Reply #37 on:
Jul 14, 2022, 04.40 pm
Good to hear that you're all good again. It seems that there have been several instances reported on this forum where after investigating different possible solutions, it turns out to be the battery that's the culprit. The battery is the easiest component to check and replace but some of us refuse to believe it's toast.
1
2
3
4
Go Up
Desert sand adventures maintenance log
dsadv
Yesterday
at 11:51 pm
New
New Members
Stevie.P
Yesterday
at 11:13 pm
First Tiger 800!
New Members
Stevie.P
Yesterday
at 11:11 pm
no power to auxiliary sockets
ped
Yesterday
at 08:09 pm
Tiger 900 items for sale
For Sale
Dizzy
Yesterday
at 07:44 pm
Bad oil
Paulhere
Yesterday
at 06:17 pm
TEKMOUNT for GPS
Sat Navs, Intercoms, Cameras, and other tech gadgets
Derchef1962
Yesterday
at 04:44 pm
What do y'all use for tank bags?
Derchef1962
Yesterday
at 04:37 pm
How To Use TigerTool V3.3 Service Utility Software
"How To" Technical Articles
eskalextric
Yesterday
at 11:37 am
Buy a rear sprocket from...?
Ben_snapper
Yesterday
at 11:22 am
