Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Clutch cover gasket tiger 800XC  (Read 1230 times)
Offline tri-vi-la
  • Bike: tiger800xc
« on: June 14, 2018, 10:51:31 PM »
Hi.
I am in Colombia with a failing clutch. Have ordered a Barnet replacement one, but am having problems finding a clutch cover gasket. A friend sourced a Tiger explorer one part number T1261430. It is from a 2012 Explorer. Anybody know if it will fit a 2014 tiger 800XC It's a long shot I know
Triumph are no longer active hear in Colombia so have no help there.
If I can't find one will have to get one made, if so does anyone know the thickness of the original one.
Thanks.... Vince  :418: but the clutch doesn't  :001:
Re: Clutch cover gasket tiger 800XC
« Reply #1 on: June 15, 2018, 05:44:48 AM »
I can't see that one fitting
Can't you get someone to get one and mail it to you? if you're stuck, I'll do it
Offline Mav
  • Bike: 800 XRx
« Reply #2 on: June 15, 2018, 07:34:57 AM »
If all else fails, you can make one yourself.
Offline tri-vi-la
  • Bike: tiger800xc
« Reply #3 on: June 16, 2018, 01:37:25 AM »
Thanks a million RTWO, I really appreciate it. I could do that but it would take a while to get here and I don't want to stick around Bogota for to long. I am gonna buy some gasket material and either get one made or make one myself.
I have the use of a garage from a canam and quad dealer.
Thanks for your offer..... Vince :031: :031:
Offline tri-vi-la
  • Bike: tiger800xc
« Reply #4 on: June 16, 2018, 01:40:52 AM »
*Originally Posted by Mav [+]
Hi Mav, that's what I will end up doing. Thanks for the video, super. Will first try to get some gasket material before resorting to cornflakes.  :084:
Thank you Vince  :031: :031:
Offline Turbo100
  • Bike: 17 Tiger 800 XRt
« Reply #5 on: June 16, 2018, 09:53:03 AM »
*Originally Posted by tri-vi-la [+]
Make your own, I have made hundreds when I was in my youth, didn't have any spare money to buy new.
Take your time, tap out the bolt holes first and pop a bolt into each hole as you tap them out, that will then give you a better chance of it being accurate when it's compleat
Offline Mav
  • Bike: 800 XRx
« Reply #6 on: June 16, 2018, 10:21:37 AM »
Make sure you eat the cornflakes first  :492:  :152:
Offline tri-vi-la
  • Bike: tiger800xc
« Reply #7 on: June 16, 2018, 04:12:29 PM »
*Originally Posted by Turbo100 [+]
Hi Turbo,
Thanks. Nice tip about the bolts. I don't think that I can get blue Hylomar here. Bolts will hold everything in place while I tap. Does tapping also work if I use gasket material???
A silly question but If I use a gasket either from gasket material or cornflakes do I still have to use liquid gasket compound or something like that as well??
Thanks.... Vince  :062:
www.rideliveexplore.com  f Ride Live Explore
Offline tri-vi-la
  • Bike: tiger800xc
« Reply #8 on: June 16, 2018, 04:17:38 PM »
Wooooow glad you told me....  :047: :008: .... Wonder who will start a new topic on which is better, cornflakes, rice krispies or weetabix....  :002: :001:
Thanks for all the help Vince
Offline Turbo100
« Reply #9 on: June 16, 2018, 09:48:40 PM »
Hi Turbo,
It would be beneficial to apply some jointing compound if possible.
The same goes for the gasket paper v a cornflakes box, better to use gasket paper but if not available any port in a storm.
Another tip is to use a very small hammer, I use one for fitting window panel pins, small and easy to tap the paper to cut through it but do no damage to the alloy cover
