Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2015 xcx side stand spring fix  (Read 621 times)
Offline Dirtbag
  • Your motorcycle is more important.
  • Bike: tiger 800 xcx
« on: June 23, 2018, 08:07:42 AM »
The stock side stand spring is just weak enough that sooner or later it's going to flip up to easy and down it goes. I saw some posts about the 1200 side stand  spring is a fix . Being My BMW 16 r1200rs is right next to my Triumph and my BMW dealer is very close . The BMW uses 2 springs and a triangler bracket. I just took 1 spring and the bracket and fit it on the Triumph and it got just the right amount of tension .total cost 13 $ ( The bmw side stand is very strong design of high technology ) Much stronger then the Triumph, But the Triumph does not cost 20k either  :031:
« Last Edit: June 23, 2018, 08:17:42 AM by Dirtbag »
Offline Bladerunner99
  • Bike: 2018 XCA
Re: 2015 xcx side stand spring fix
« Reply #1 on: June 23, 2018, 11:02:09 AM »
So does this BMW spring solve the Triumph side stand problem?  If so can you please provide BMW part numbers.
Ride to work. Work to ride
Offline Dirtbag
« Reply #2 on: June 24, 2018, 06:45:25 AM »
Qty 1 46537653538 5.07
Qty 1 46532345275 11.47
  • Bike: 2018 XCA
« Reply #3 on: June 24, 2018, 01:10:34 PM »
Thank you
