Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Rear brake pedal height - Adjustment ?  (Read 769 times)
Offline sezian
« on: June 28, 2018, 07:29:08 AM »
I would like to raise my rear brake pedal slightly more but don't know if this is possible  :187:
I have adjusted the threaded section to what I think is the max (just about get a full nut on the bottom) but is it possible to do anything else to raise the pedal a bit more  :261:
Any advice / suggestion would be much appreciated  :028:
Re: Rear brake pedal height - Adjustment ?
« Reply #1 on: June 28, 2018, 11:58:39 AM »
Altrider make a device to help when using it standing up - can't recall what it's called
That would certainly raise it
« Reply #2 on: June 28, 2018, 03:25:51 PM »
 :0461: Wot he said ^^
Having had similar issue as OP and reaching the same conclusion -- not enough adjustment -- I fabricated a piece similar to what Altrider offers.
Solved the problem.
"Working on a motorcycle, working well, caring, is to become part of a process, to achieve an inner peace of mind.
The motorcycle is primarily a mental phenomenon."
Robert M. Pirsig
