Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: I have a 2015 tiger xc  (Read 1180 times)
  • Bike: XC,XCX, CB1300,
Re: I have a 2015 tiger xc
« Reply #10 on: August 14, 2018, 12:06:27 AM »
Question for T800XC--
You wrote:
[/quote]
All models use a stepper motor! On the Mk1 it's for idle control only, but on later models it's used for full ride-by-wire.
[/quote]
I haven't seen the later models you refer to, T800XC,  are you saying they use the same stepper motor found on earlier cable models as the actuator for the ride-by-wire model? I would have thought it would be a different type of stepper motor. Can you pls confirm, I would be interested in some mods if so.
« Reply #11 on: August 14, 2018, 09:32:27 AM »
The key word is 'a', not 'the same'.
The gen 1 bike 'idle' stepper motor is 155.
http://www.worldoftriumph.com/triumph_motorcycle_parts_locator?block_01=&block_02=100057403-0-2&block_03=560041
The gen 2 'ride by wire' bike stepper motor is part of the throttle body and 1300.  :005:
http://www.worldoftriumph.com/triumph_motorcycle_parts_locator?block_01=&block_02=100068522-4-2&block_03=560048
Offline Earl
  • Bike: Tiger 800 xc
« Reply #12 on: August 14, 2018, 09:09:34 PM »
Ok next question which fuse is for headlights so I dont flatten battery in process
  • Bike: 800XC & Explorer
« Reply #13 on: August 14, 2018, 10:12:56 PM »
*Originally Posted by Earl [+]
Should be no.6 (20A) in the rear fuse box, but double check that in your owner's manual.
Offline Earl
« Reply #14 on: August 15, 2018, 08:30:15 AM »
Cheers will do 👍🏻
