Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Throttle bodies question  (Read 2932 times)
Offline Trekker
  • Bike: 2011 800 XC
Re: Throttle bodies question
« Reply #20 on: July 18, 2018, 02:31:58 PM »
Just out of interest, can the throttle bodies be synced using Tune ECU on an Android phone or do you specifically require the dealer tool?
Offline T800XC
  • Bike: 800XC & Explorer
« Reply #21 on: July 18, 2018, 02:44:24 PM »
*Originally Posted by Trekker [+]
TuneECU, Dealertool & TigerTool can all check throttle body balance allowing you to adjust (with a screwdriver) & re-check them if necessary.
To use TuneECU on later models (Mk2 & Mk3) you can only do this with the Android version, whereas Dealertool & TigerTool work on all models.
« Last Edit: July 18, 2018, 02:46:02 PM by T800XC »
Offline Trekker
  • Bike: 2011 800 XC
« Reply #22 on: July 18, 2018, 05:15:47 PM »
Many thanks for this info T800, useful for the future
Offline philmcglass
  • Bike: Tiger 800 2013
« Reply #23 on: July 18, 2018, 07:48:42 PM »
« Reply #24 on: July 18, 2018, 08:09:31 PM »
*Originally Posted by philmcglass [+]
This is the mk1.  What of mk2 & 3?
Offline philmcglass
« Reply #25 on: July 18, 2018, 08:40:47 PM »
Not got that manual.
Will it be a lot differnent?
« Reply #26 on: July 18, 2018, 09:43:21 PM »
Traditional cable v ride by wire
Offline The Reaper
  • Bike: 800 XRX
« Reply #27 on: July 19, 2018, 11:12:00 AM »
If you look at the pictures I posted of my throttle bodies the adjustment screws are not clearly visible.
Offline JMc
  • Bike: tiger800
« Reply #28 on: July 19, 2018, 01:19:15 PM »
that's because the one photo of the throttle bodies on their own is from an earlier cable operated throttle, yours is a ride by wire and has the servo motor on the top of the throttle bodies to open and close them when you twist the throttle, which is why its looks different.
I would imagine the adjusters are still there but under the metal casting of the inlets....perhaps!?
Offline The Reaper
  • Bike: 800 XRX
« Reply #29 on: July 19, 2018, 01:31:42 PM »
*Originally Posted by JMc [+]
Yes, I realise the illustration is from a pre 15 model and my bike is ride by wire, which is why Im guessing the adjusters are possibly in a similar place, but would be handy to get confirmation from someone who has actually done it. 🙂
